Author Topic: EWI R8UE-12 or Road Ready RR8UED?  (Read 3903 times)
Lukas Mondoux
« on: February 08, 2009, 10:19:07 pm »
Hello all,
As I've been building my PA setup I've got enough rackmount equipment now to justify getting a rack to mount it in. The gear I'll be mounting is:
Furman PL-Plus DMC (10.5" D 1U)
Rane DC24 (5.3" D 1U)
Rane AC23B (5.3" D 1U)
Rane ME60 (8.5" D 2U)
So thats 5U worth of rack equipment and I would want to leave some room for a little expansion which is why I'm going with an 8U rack.
I have 2 questions, the first is whether I should go with a shallower rack by EWI (12" deep) or if it would be better for some reason to go with a 14"? (I can't see any reason right now I would need an 18" deep.)
 http://www.audiopile.net/products/Cases/RUE-12_series_rack_c ases/R8UE-12/R8UE-12_cutsheet.asp
My other question is about EWI itself, are they a good company? I've known Road Ready to be the standard as far as cases go. The EWI is significantly cheaper at $120 as opposed to $225 for the Road Ready.
 http://store.roadreadycases.com/dyn_prod.php?p=RR8UED&k= 113881
Thoughts?
-Lukas
-Lukas
Evan Kirkendall
Re: EWI R8UE-12 or Road Ready RR8UED?
« Reply #1 on: February 08, 2009, 10:46:56 pm »
Get the EWI case. The good folks at audio pile are great to work with and sell a quality product. Get the 14" one to allow room for deeper pieces of gear, and room for coiling cables in the back of the rack.
Evan
Bob Hulme
« Reply #2 on: February 08, 2009, 11:14:01 pm »
Lukas,
I've got EWI cases and Road Ready cases and both are about the same build quality. Go for the better price, and as Evan said, Audiopile are great folks to deal with.
Good luck,  Bob H
"I finally thought I had the rat race won, then along came faster rats"
Tony "T" Tissot
    • http://www.4dbsound.com
« Reply #3 on: February 09, 2009, 01:37:14 am »
EWI is every bit as good as RR (I have both).
Audiopile is much easier to deal with.
(RR sent me on an endless run-around (when the interior lid on a mike case warped.)
As for depth?
I keep at the deeper size as they pack equally in the trailer - and give me more room between the back of equipment and the patch panels on the rear rails.
I use the very narrow just for Monitor EQs and for the "walk-in" gig rack.
MNGS
ProSoundWeb - Home of 50,000 audio professionals - and two or three curmudgeonly SOBs.
Lukas Mondoux
« Reply #4 on: February 09, 2009, 03:26:32 am »
Tony "T" Tissot wrote on Mon, 09 February 2009 00:37
As for depth?
I'm planning on installing patch panels on the back for easy inputs and thru outs. What kind of setup do you use? Mind taking some pictures?
-Lukas
-Lukas
RYAN LOUDMUSIC JENKINS
« Reply #5 on: February 09, 2009, 09:38:49 am »
Lukas Mondoux wrote on Mon, 09 February 2009 01:26
-Lukas
I have an even better idea for you!
Buy the EWI rack from Audiopile!  Then buy the PFQ-101 or PFQ 202 and get the appropriate cables either ADMQ 15-16 or ADMF 15-16 or the 15' DM Patch depending on your applications!  Then buy a couple TRS cables to patch your gear into the PFQ and you are up and running with a very clean looking and easy to connect setup for less money than making your own and you don't have to track down the silly crimp tools for a multipin connector.
In addition to Audiopile having a bunch of cool products at great prices, Liz and Mark are WAAAAYYYYY cool people to do business with.  They are by far my favorite supplier just because of how nice they are!
Ryan Jenkins
"Two days until the end of when I don't know what to think.  Three days until I start the cycle all over again!"
Please visit my website at http://www.murphygirl.com
Chris Van Duker
« Reply #6 on: February 09, 2009, 12:47:28 pm »
Between Road Ready and EWI, I prefer EWI. We've had a few RR racks and cases which haven't held up that well, but no problems with the EWI.
-Chris
Mike {AB} Butler
    • http://www.3alchemy.com
« Reply #7 on: February 09, 2009, 04:09:38 pm »
Ditto on the EWI, and what the others have said about Audiopile. BTW, I would advise against the deeper cases for signal processing units - unless you plan to put patch panels on the rear, as the deeper cases make it harder to patch to the units. I have a 12U of the least deep of all the EWI offerings, and it's full up. My fault for having 2U EQ's..  Embarassed
Regards,
Mike Butler,
Principal, Technology and Operations,
Dascott Technologies, LLC
Lukas Mondoux
« Reply #8 on: February 09, 2009, 04:51:46 pm »
RYAN LOUDMUSIC JENKINS wrote on Mon, 09 February 2009 08:38
-Lukas
Hmm. I took a look at what you're suggesting but I don't believe that's what I need. He patchbay I would build would have L/R XLR in, L/R XLR out, and L/R XLR thru. All of my connections at this time are XLR not TR/TRS.
I've never seen a patchbay like that before though, what would it commonly be used for?
-Lukas
« Reply #9 on: February 09, 2009, 04:56:44 pm »
Multi-pin cable stays connected to mixer in it's case.  You show up to the gig, take the EDAC cable and plug it into the connector on the patch panel, everything has just been plugged in in less than 30 seconds.  No worries about patching incorrectly because it is always the same once you set it up correctly the first time.
Ryan Jenkins
Page created in 0.036 seconds with 20 queries.
