Decide what you want this sub to do and then order your priorities. When we were looking to upgrade, small size was my number one need due to trailer space followed by weight and then SPL. Cost didn't really make a difference for us unless it would have been signigicantly higher.
We do small venue live blues rock, so extended low frequency isn't as important for us as it could be for others. If you haven't already, learn how to decypher spec sheets and compare measured response charts when possible as one company's -3dB point or peak SPL will be figured differently than anothers.
Here's the list of options I wound up with for my criteria. Note that I roughly calculated the SPL figures back to a program power level when the spec sheets published peak power level figures. Later we decided to limit our choices to a max weight of 80lbs as I too carry an AARP card and the rest of the crew (the Band) is all female.
" target="_blank">
We had rented the SRX previously and listened to the MRX in a store setting. The only other model that we demoed was the TH-Mini which was what I wanted as long as we like the sound of it and it lived up to it's specs. We are now very happy with our two TH-Mini's, but they wouldn't be the right subs for others I know.
Good luck choosing, Winston
PS. Does your "baby boomer" crowd really like it at 110dB? Where/how is that measured? Must be the Metal head boomers,
95-98dBa at FOH in small venues is about our usual.
