Yeah, These are the old Thunder boxes.....
More of the story:
These were built as a single 3-way cab, about the size of a short industrial freezer.... ~500-600lbs each. The MH102 section was built attached to a BH550. As described by the builder, these were originally loaded with all TAD drivers.
I have two pair of boxes, one set loaded, one set with only the 12's (which was a buying point, I now own 4 TAD 12" speakers that would probably e-bay quite well. Or go into a really sweet monitor rig, etc.....)
The BH550 sections in my loaded boxes currently have JBL 2225's. I'm not sure I like the drivers, but need to do some calcs using the dimensions of these boxes, not using datasheets from EAW; to see what modern 15 would work better. If there is one. I'd love to hear TAD's but dont think I should even look into buying 8 15's...
I'd like to drop the K8's because I am using 2450 diaphrams in them and would prefer a (again with this theme) more modern (parts friendly) driver.
I plan on re-working all the cabs this winter so that I endup with 4 BH550ish boxes and 4 MH102ish boxes. This would include reinforcement/checking of all seams, building fly hardware (yes I am an Engineer, and know a couple PE's to have it checked.) for them, repaint, and general maintenance.
Obviously they will need tons of tuning, at least I think that a good work over with software and etc will really help. about a year ago I downloaded the trial copy of SMAART and once I had dialed the appropriate delays they jumped right out.
The Venue owner and Designer love these speakers, the large format horns fit with their vision, they have no desire to use modern boxes. I do need to find an efficient subwoofer to go with them, the BH550 clones tend to unload at ~60-65Hz. I'm thinking 4x LabSub's or TH115's per side would really cover me from 30-70.
this puts X-over points @70, 250, (1.2)2.2 in a quad processed system. With the right setup in the processor I think that they'll sound really nice.
The venue is:
www.theatrebizarre.comObviously not your average Theatre!
Thanks for the help, any other info will be greatly appreciated.
