By 1080p I'm referring to the consumer 16:9 standard 1920x1080. I'm thinking this might be a cheap way to get 1080p in my home theater.
The rotation can be done right on the PC in the video drivers. The only tricky part is finding a triple output video card that allows it all to be one desktop and not 3 separate desktops connected together(ie. not extended desktop). With extended desktop video dosen't exactly play nice across different desktops. There couldn't be any overlap because there is no way to do that in the regular video drivers. It might be doable in linux.
I would have to build 3 custom right angle mounts to go on the wall behind the screen spaced perfectly, at exactly the vertical center of the screen. There wouldn't need to be a huge area behind the screen, because each projector is only covering 1/3.
Currently 1080p projectors are pretty expensive. The cheapest I've seen was $2500 but only 1200 lumens. With this setup I would have 6000 lumens(3x 2000lumens) using $600 DLP projectors.
Then again when the time comes around to change 3 bulbs vs 1, the total cost of ownership favors a single 1080p projector.
Maybe I should just convince my boss to buy a 1080p projector that I could borrow for watching 1080p movies and just get a 720p projector for day to day use...
