Pages: [1] 2 3 ... 13   Go Down
Author Topic: The BT (Balanced Tilter)  (Read 39865 times)
Nimrod Webber
    • http://www.boniton.co.il
« on: October 22, 2008, 02:27:56 am »
My hands are itching… here is my next project.
I have started thinking about this while building the Stand Tricks.
See some details here: http://billfitzmaurice.com/phpBB2/viewtopic.php?t=4378&h ighlight=stand+trick
After using them for a while I have come up with some insights and finally completed the design.
This is my take for a tilting adaptor (for a speaker on a stick) that keeps the COG of the cab over the pole's center
at any tilt angle within its tilting range (-12˚… 0˚ … +12˚).
I limited the tilting angle to 12˚ as my experience with the Stand Tricks never encountered a need for more then about 8˚.
The design is true for a cab heaving its COG at about 300mm from the bottom, as this is the average of the cabs I am using.
(and of coarse the cab's top hat being in line with the cab's COG).
The principle and geometry design of the BT is complete.
Only some minor mechanical issues to decide and will start fabricating.
http://i31.photobucket.com/albums/c360/boniton/BT.jpg
Any insights are welcome…
Smile
...so God created SOUND, And then God said...
Balanced Tilting Sounds Better... http://www.bt-12.com
Arjan van Gog
Re: The BT (Balanced Tilter)
« Reply #1 on: October 22, 2008, 05:40:10 am »
I've also been doing some thinking on this, triggered by some recent posts here. I came up with the following:
http://www.prognosis.nl/Balancing%20tilter.png
It's just a quick rough sketch of the concept. The idea is that you can measure the balance by checking the clearance between the small bumps on the two horizontal plates and that you can balance it by shifting the upper plate. When the bumps touch, there is too much imbalance.
The springs are there to make it easier to obtain an 'almost balanced' situation, otherwise the slightest imbalance would cause the bumps to touch.
An alternative to the touching bumps approach would be an actual balancing arrow pointing down from the upper plate which should point straight down in a balanced situation.
The horizontal shifting could  be done either simply moving the speaker and upper plate by hand, or you could add a threaded axis that could be turned for easy and precise adjustment of the horizontal offset.
I have drawn rollerbearings between the two plates but if you include the threaded shifting axis they may not be necessary if the friction between the two plates is low enough. In fact that would have the advantage of the horizontal shift position being secured automatically, the only way to change it is to turn the axis and that's not gonna happen spontaneously.
The angle is fixed in this drawing but obviously you can use an adjustable mechanism instead. This idea is only about obtaining balance with any speaker regardless of its geometry and center of gravity, and how to check that balance.
So what do you think?
Chris Gruber
« Reply #2 on: October 22, 2008, 07:25:52 am »
Nimrod Webber wrote on Wed, 22 October 2008 01:27
Smile
I think your idea is great and would love to see a working version. I am always a bit nervous about just tipping them forward and throwing off the balance.
-Chris
Arthur Audio
"It never ceases to amaze me how many sound guys think the measure of their work is solely defined by whether or not their subs are capable of sonically vaporizing squirrels from 20 meters."
Jeff Babcock
« Reply #3 on: October 22, 2008, 11:10:57 am »
Good stuff Mr Webber.  If you eventually are ready to sell production versions please let me know.
« Reply #4 on: October 22, 2008, 11:38:07 am »
Hi Nimrod-
That looks very interesting and relatively simple.  I don't see any immediate issues.
Let us know as you progress with this.
Have fun, good luck.
Tim Mc
Dick Rees
« Reply #5 on: October 22, 2008, 11:44:51 am »
Gentlemen.....
I applaud your efforts and thoughts on design.  I cannot offer a drawing but I would suggest this:
Rather than an adjustable angle device with several parts, could you not focus the efforts more on the cabinet rather than the stand.  A fixed angle adaptor (say 8-10 degrees or whatever seems the best average) would allow stronger, welded connections of the parts.  To adapt cabinets with slightly differing COG you could simply make the horizontal bar (connecting the female stand mount and the male speaker mount) a slider or at least provide a series of holes 1" or so on center to allow you to move thing as needed and secure it with a locking pin.  Not very elegant, but stronger, I think, if you can live with a fixed angle.
DR
St Paul
PS
Once you establish the proper length of the bar for your cabs you would of course want to use lock nuts.
 Neo-Luddite, Rocket Surgeon
"Pay no attention to the man behind the curtain."
Charlie Zureki
« Reply #6 on: October 22, 2008, 11:46:12 am »
Smile
Hello,
   Very nice, and relatively simple design. You have a product, now get to the manufacturing.  I'll take four in Flat Black. (No DJ bling for me)
Seriously, I need four.  Smile
Thank You.
Hammer
Be prepared, you'll need it!
Timothy Allan Jones
    • http://www.myspace.com/tajacousticguitar
« Reply #7 on: October 22, 2008, 11:48:51 am »
I'll bite...
Does the GOG change because of magnet wt.?
I envision the cab becoming rearward heavy as the forward tilt increases. At max height extension, a stand could be vulnerable to tipping back.
tj
Coffee house boards need a blender button.
Charlie Zureki
« Reply #8 on: October 22, 2008, 11:52:12 am »
Timothy Allan Jones wrote on Wed, 22 October 2008 10:48
I'll bite...
tj
 Timothy, what is GOG?
 I'm sure you mean center-of-gravity?
 Hammer
Stephen Payne
« Reply #9 on: October 22, 2008, 11:55:58 am »
I like the concept. You better hope Uli dosen't!
Steve
Pages: [1] 2 3 ... 13   Go Up
Page created in 0.05 seconds with 18 queries.
