Author Topic: Multiple size powered subs -- good or bad idea?  (Read 2260 times)
Kirby Yarbrough
« on: October 13, 2008, 03:59:26 pm »
I have a pair of QSC HPR181i powered subs, and they do very well for the small events I do.  I sometimes do smaller rooms where I'd like to use HPR151i powered subs, because they're lighter, smaller and have more thump at lower levels, but I don't have them yet.  It'd be great to use all four for larger events, but I'd like to know if using two different sized drivers is a good or bad idea.  Both boxes are identically powered and have the same 100Hz crossover.  Thanks in advance for your help.
Kirby
[Edited to clarify I don't have the 15s at this point]
Dave Barker
Re: Multiple size powered subs -- good or bad idea?
« Reply #1 on: October 13, 2008, 04:08:08 pm »
I did a small outdoor event and used a pair of the 181's with 151's stacked on top and 152's on top that and it sounded great.  No problems at all.
Matt Vivlamore
    • http://www.meerkatsound.com
« Reply #2 on: October 13, 2008, 04:08:48 pm »
You might run into cancelation problems.  Depending on the room and PA layout.
I would run the 18” the standard way and used the 15” as supplemental subs.  I would also place them in an AUX sub fashion.  So that you can adjust them as needed.
Find us on the web at: meerkatsound.com
I'm using: EV QRx212 over JBL SRX718s(2) with Crown IT's and MRX512m & MRX525 on monitors with XTi's; all controlled by Yamaha LS9-32.  I have a bunch of other stuff too.
Sam York
« Reply #3 on: October 13, 2008, 04:09:13 pm »
Bad idea really, will probably muddy the sound if anything.
If that's what's already in your inventory then the only way round it I could see would be by using a DSP or active crossover to run them in different frequency bands, i.e. sub and mid bass/kick bins.
Not sure whether you can bypass the internal crossovers as I've never used these, also no idea how they will sound for the same reason, but when you see 15s and 18s in the same rig this is how it will usually be done.
EDIT: a quick glance at the QSC website shows that all the cabs accept a full range input (i.e. so it can be band limited externally) so in theory this would work. They don't include anything as useful as a frequency reponse plot so not sure how well it would work in practice, although from the frequency specs given the 18 appears to go lower than the 15, as you'd expect.
Failing that the only other thing I can think of is getting rid of the 18s, buying four 15s and using those where you'd use 2 18s before, should go as low and be louder. Maybe buy another 2 15s for the big gigs to give you six. Or just buying more 18s and using those everywhere.
This could be rather good actually, anyone out there running a four way HPR rig?
(side note, I'd expect the 12" mid tops to work better in this config than the 15" ones, as they wouldn't have to deal with as much mid range signal)
Sam York
« Reply #4 on: October 13, 2008, 04:09:56 pm »
Matt Vivlamore wrote on Mon, 13 October 2008 21:08
How would that get round the cancellation problems though Matt?
Bryan Bartone
« Reply #5 on: October 13, 2008, 04:40:29 pm »
The QSC HPR subs have an internal crossover.  So the sub's amp only sees sub frequencies.
Sam York wrote on Mon, 13 October 2008 15:09
Sam York
« Reply #6 on: October 13, 2008, 04:44:48 pm »
Bryan Bartone wrote on Mon, 13 October 2008 21:40
Doh. Me being an idiot. I was only considering the filtered output to the mid top cab.
I'd get out my screwdriver and wire the input to be after the crossover, but it'd be a kludge (I customise a lot of things  Twisted Evil )
If QSC published the specs of those filters you could probably even work around it, it'd just mean the 15s only going up to 100 or wherever their LPF is, when in a four way setup with 12" mid tops you'd want the mid bass to go higher than that.
I know someone who has a HPR rig and I have a Driverack, I feel an experiment coming on!
Douglas R. Allen
    • http://-
« Reply #7 on: October 13, 2008, 04:57:22 pm »
I asked QSC this very question and they told me the Phase and Freq response of the two subs was close enough to use them  together. QSC has a chat forum. You should post the same question there as well.
Douglas R. Allen
Allen Audio
"The worst thing is."
"You can't teach common sense."
Bryan Bartone
« Reply #8 on: October 13, 2008, 05:03:15 pm »
Which makes me happy that I bought the 15's over the 18's. Smile
Douglas R. Allen wrote on Mon, 13 October 2008 15:57
Douglas R. Allen
Matt Vivlamore
« Reply #9 on: October 13, 2008, 07:20:50 pm »
Sam York wrote on Mon, 13 October 2008 16:09
If the cancel each other out, go ahead and pull down the slider and not use them.
Page created in 0.039 seconds with 21 queries.
