[quote title=Micky Basiliere wrote on Mon, 06 October 2008 20:59
I typically use my SR4726's for a full range passive mix but, i wonder if adding some subs underneath
might do more damage in my FOH vocal mix,than it's worth? This is kind of what my question is all about.[/quote]
What size stage and what size room are you usually working in? If you tweak the side fills right you should not have much of an issue with them in the vox mix at FOH. Don't let the subs become sloppy on stage, just use them for some low end punch in the kick drum and bass gt.
