Phil,
Before you go and trade in your PLX amps, as others have said, I would upgrade your supply cables to 10 or 12 gauge. Personally I use 10 gauge over 25'for my amp racks. Never plug into a circuit on a dimmer.
I have PLX, PLX2 and PL series amps and I have never had an amp shut-down. Sometimes I've had to put 2 bridged 3402, 1 stereo 3402 and 1 1602 on 1 20 amp circuit, however I wasn't close to running full power. Generally if more circuits are available I split that rack up 2 and 2. You just have to get a feel for how hard the system can be pushed based on power source available.
Sometimes a Poor Mans Distro means running (10 or 12ga)extension cords all over the place to get the power you need. Many venues don't have 30-50amp plugs where you need or period.
BTW check Home Depot before you have cable shipped from an online source. Also residential (Harry Homeowner) wiring books are readily available at HD which should explain and picture all you would need to know to wire a quad box. When in doubt ask though.
Ken
