If it doesn't need to be in conduit, I'd rather not put a bunch of cables in conduit. If the cabling is plenum cable, it can be a challenge, as the insulation can really tear easily, and if it is a loose PVC/vinyl it can be a real pain, especially for a long pull with several bends.
I would not object to cleaning up a bunch of wires laying across the ceiling, but running speaker cables in a conduit doesn't really gain you very much, especially comparing the cost in an existing install.
Maybe it's just me, but I've found that pvc/vinyl cable needs a lot more space in a pipe than THHN. And pulling a pull string thru a pipe with several 22-2shielded cables is pretty much a waste of string, unless it's a really short or straight run.
YMMV, of course....
