Micky Basiliere wrote on Sun, 06 July 2008 20:27 |
ME!!! Sag??? That is complete BS!!! I have NEVER seen Any sag w/ Spans over 40 ft. Global is a GREAT product!
Micky Basiliere wrote on Sun, 06 July 2008 20:28 |
If it sags... Your Towers suck!
Even if you were right, which you are not, the way you express yourself is impolite. After participating here for a while, you will figure out that the obnoxious replies will only gain you disrespect in kind, to the extent that if you ever have a legitimate point to make it probably will be ignored.
I'm a dealer for Global truss, and regularly put 800 - 900 lbs. of truss, lights and sound up on a pair of Applied L16 lifts (which BTW do not "suck", they handle the load perfectly well). I have found that if I extend my total truss length beyond the typical 40'ish feet, I still place the stands inboard to keep the total "spanned" distance under 45'. With 60' of truss in the air I leave about 7-8' per side extending beyond the stands, and hang speakers to the outside, directly adjacent the stands to counter the spanned load. If all that weight is placed inbetween with the stands at 45', the truss WILL sag a few inches in the center.
If I moved the stands out closer to the end of the truss, thereby increasing the "span", the truss will sag noticeably even with NO gear on it.
