Author Topic: Yorkville UCS1 vs UCS1P  (Read 10191 times)
Jeff Babcock
Re: Yorkville UCS1 vs UCS1P
« Reply #10 on: June 26, 2008, 10:49:59 am »
Todd Michael wrote on Thu, 26 June 2008 07:43
The voice coil is 3".
Todd
Hi Todd,
Can you please change your website to reflect this.  The powered version currently shows 4" VC
Also I can't recall where but believe I heard something about the interior cabinet dimensions/horn being adjusted somewhat from the passive to the powered model.  Are they directly compatible or not?
Thanks
Jeff
Randy Frierson
« Reply #11 on: June 26, 2008, 11:40:57 am »
My rep says they have never had this issue, but I'd like to hear from actual people who owns them, maybe i just got 4 out of a bad batch...They get loud and sound real good for the money, very well built, i was a little shaky about the way the amp is mounted`in there as i wanted to lay these on their sides and couple horns, but just rolled them out on their wheels, 2 really did a decent job under 4 850's..i was pleasantly surprised  R
Todd Michael
« Reply #12 on: June 26, 2008, 04:51:15 pm »
I checked the website after first reading your post and I could not find any mention of a 4" coil for the powered version, and I still can't. I will ask the web guys to double check though.
The powered cabinet is the same in all details except it is wider to accommodate the amp, dimensions are on the web site. The powered cabinet with the slightly larger horn (wider = more horn volume) has a little more output down lower in its response. Yes they are compatible.
I have not heard of any limiter failures to this date, and I would have if there was a problem. That is still no excuse for the 4 units you received and I will follow up with our Service Department to find out more details.
Todd Michael
Speaker Design Lab
Yorkville Sound
VTC Pro Audio
Paul Magro
    • http://www.valleysound.net
« Reply #13 on: June 30, 2008, 06:51:18 pm »
  I've got 6 of the UCS1's and I couldn't be happier.  For me running passive is the way to go as my setup changes and I can use the power amps for different speakers as need be.  I run them 4 or 8 ohm off a couple of PLX 3602's.  Gobs of low end for the festivals with the dub bass jam bands!  If I had an install, I would go the powered route.  Apples to oranges!
Paul Magro
Valley Sound
802.356.7001
http://www.ValleySound.net
tom hughes
    • http://myspace.com/djtomfoolery
« Reply #14 on: July 19, 2008, 03:59:03 am »
UCS1 and UCS1p mating?
Can the UCSP1 handle 4 ohm? Seems as if it should. I was wondering if i could take a pair of usp1 and add in a connector to run a usp in tandem from the amp pack? Anyone thought of trying this? My only fear I think would be over heating, but with two fans it should stay cool, right?
I assume if it was that easy people would already be doing it on this forum, so please explain to me what the issues would be.
  Tom
Jeff Babcock
« Reply #15 on: July 21, 2008, 04:18:07 pm »
Todd Michael wrote on Thu, 26 June 2008 16:51
Todd Michael
Speaker Design Lab
Yorkville Sound
VTC Pro Audio
Thanks Todd,
The website is indeed correct now.  2 units just came in, looking forward to listening.
Jeff
Matt Vivlamore
    • http://www.meerkatsound.com
« Reply #16 on: July 21, 2008, 04:25:43 pm »
Jeff did you get in 2 UCS1 or 2 UCS1Ps?
can you compare both against each other and see how they react and such.
Find us on the web at: meerkatsound.com
I'm using: EV QRx212 over JBL SRX718s(2) with Crown IT's and MRX512m & MRX525 on monitors with XTi's; all controlled by Yamaha LS9-32.  I have a bunch of other stuff too.
Jeff Babcock
« Reply #17 on: July 21, 2008, 04:28:01 pm »
tom hughes wrote on Sat, 19 July 2008 03:59
  Tom
Seems like a perfect way to void your warranty...
I would definitely NOT try this.  It might possibly work but will increase your risk of damage.  The amp probably is not going to give you double the power at 4 ohms that it does at 8, meaning you will push it harder and risk thermaling it faster too.  The amp is most likely optimized specifically for best power/performance at the impedance it is driving.
Page created in 0.035 seconds with 19 queries.
