Author Topic: Yorkville UCS1 vs UCS1P  (Read 10181 times)
Phillip Mispagel
« on: June 22, 2008, 06:56:54 pm »
I'm curious about the power and SPL rating differences between the UCS1 and UCS1P.
The UCS1 has a program power of 1000 watts with an SPL rating of 132db.  The UCS1P has a program power of 1500 watts with the same SPL rating of 132db.
Is this correct?  What is the additional 500 watts used for, if not to push out more sound?
Tony "T" Tissot
    • http://www.4dbsound.com
Re: Yorkville UCS1 vs UCS1P
« Reply #1 on: June 22, 2008, 07:01:39 pm »
Apples to Oranges.
One is the driver - speaker rating; the other the internal amp ratings.
MNGS
ProSoundWeb - Home of 50,000 audio professionals - and two or three curmudgeonly SOBs.
Matt Vivlamore
    • http://www.meerkatsound.com
« Reply #2 on: June 23, 2008, 11:23:06 am »
I am pretty sure Tony has hit it on the head.
From what I have been told (from Yorkville), the UCS1 and UCS1P are using the same driver.
Find us on the web at: meerkatsound.com
I'm using: EV QRx212 over JBL SRX718s(2) with Crown IT's and MRX512m & MRX525 on monitors with XTi's; all controlled by Yamaha LS9-32.  I have a bunch of other stuff too.
Phillip Mispagel
« Reply #3 on: June 23, 2008, 02:38:38 pm »
Yep, thank you for the info.
Jeff Babcock
« Reply #4 on: June 25, 2008, 10:56:48 am »
FWIW the two models do not use the same driver, the powered version has a larger voice coil.  While they will sound similar as far as I am aware, they have made other changes to the powered version and it is not directly compatible with the passive version.
Matt Vivlamore
« Reply #5 on: June 25, 2008, 11:26:09 am »
I am just reporting what Yorkville told me about the drivers...
Quote:
The woofer used in the Unity subs has a ferrite magnet (P/N: 7447).
The U15 and U15P use the same HF and MF drivers.  However the LFs are different, the U15 uses an 18Sound woofer and the U15P uses a B&C woofer.
I was asking about ordering some replacement drivers for my Unities and I asked if there was a difference in the drivers between the powered and non-powered speakers.  I was going to order spares to have on the shelf just incase something happened.
Conversation was dated: March 2008
Things may have changed since then.  Does anyone have a parts order catalog to confirm the part numbers are the same or different.
Right now, I am debating about buying 2 more UCS1 and a Pro9200/PL380 amp OR selling the 2 UCS1 and buying 4 UCS1Ps.
Todd Michael
« Reply #6 on: June 25, 2008, 04:27:49 pm »
The UCS1 and UCS1P use the exact same driver.
Todd Michael
Yorkville Sound
VTC Pro Audio
Randy Frierson
« Reply #7 on: June 26, 2008, 01:01:59 am »
look at the yorkville web site, by the specs they show they use a different driver, so which is it a 3" v/c or a 4" v/c..
Not to bash yorkville but i ordered 4 UCS1P's, (1) out of the box had limiter issues, got replacement and then another failed again with limiter issue.. we are sending all 4 back as customer has no faith and wants something else, what I will say is they sounded great, very impressive, if they get the limiter issue fixed they are a great value and have gobs of output...R
Todd Michael
« Reply #8 on: June 26, 2008, 07:43:42 am »
The voice coil is 3".
Todd
Mike Pyle
« Reply #9 on: June 26, 2008, 10:03:23 am »
What was the issue with the limiter?
Mike Pyle
Audiopyle Sound
707-315-6204
Dealer: Yorkville, EV, QSC, RCF, KV2, FBT, EAW, Danley, SLS, Turbosound, dBTech
 APB,A&H,Audix,Shure,Powersoft,RoadReady,K&M,Ultimate ,Global Truss,DENON,Chauvet,Elation...
Page created in 0.033 seconds with 18 queries.
