Author Topic: how to hook up my eaw subs???  (Read 9681 times)
Michael Webb
« on: February 26, 2011, 06:50:17 pm »
 :-[ trying to hook up eaw sb 750 zf using qsc rmx 2450 in bridge only the top speaker plays in both cabs pulled off back plate of cab and it uses all 4 wires i only have 2 in my speakon michael  270 445 1044
michael l
Thomas Lamb
Re: how to hook up my eaw subs???
« Reply #1 on: February 26, 2011, 08:06:21 pm »
NL4 Two Driver Subs:
Pin 1-   Driver 1 negative
Pin 1+   Driver 1 positive
Pin 2-   Driver 2 negative
Pin 2+   Driver 2 positive
Except DCS2, FR250z, LA128, LA128z, & SBX220
pin 2- = negative
pin 2+ = positive
pins 1-/+ = loop through
credit: EAW application support pages
Basically you are going to need to make a cable with +1 and +2 ,-1 and -2 tied together there are a couple other ways to do it as well but thats it. If you dont care about having the cabinet "STOCK" you could move the + and - 2 wires in line with + and - 1 wires.
T
bigTlamb
Michael Webb
« Reply #2 on: February 26, 2011, 10:33:59 pm »
pin 2- = negative
pin 2+ = positive
T
  but what do i do on amp end it is qsc 2450 in bridge mode
michael l
don mcmeckan
  • Vancouver Island B.C.
« Reply #3 on: February 26, 2011, 11:47:25 pm »
Michael, the two + lines on your cable go to positive on your banana plug.
The - lines go to minus on the banana plug.
Plug your banana plug into the two red binding posts on the amp ( ch 1 is positive ).     Enjoy Buckets of Bass!
Don
Thomas Lamb
« Reply #4 on: February 27, 2011, 10:24:23 am »
Don
If you are in bridge mode the back of the amp will have directions showing you which speakon to plug into for bridge mode or which binding post to use typically both positives and they will will be labeled for proper phase.
bigTlamb
Sheldon Harris
« Reply #5 on: February 27, 2011, 09:25:33 pm »
michael, save yourself all the trouble and guessing and get yourself a speak-on to banana cable. it should have one nl4 on one end and two banana plugs on the other with 4 conductors inside.
for bridge mode, select the correct dip switch on the back of the qsc (very important) i have seen guys make mistakes with the switches and they know what they are doing. put both banana plugs in the two red binding post outputs with the positive end into the positive end and negative into negative.
if you want to use the subs driven by both sides of the amp. simple select stereo or parallel on the amplifier and plug each banana plug into ch1 and ch2
duane massey
« Reply #6 on: February 27, 2011, 11:12:16 pm »
I would strongly suggest not bridging the amp if you are using one amp for 2 cabinets. I assume the cabinets have 2 8-ohm drivers in each, so driving all four woofers with one channel would be a 2-ohm load, not a good idea for a bridged 2450.
Duane Massey
Houston, Texas
don mcmeckan
« Reply #7 on: February 28, 2011, 12:08:08 am »
Good catch Duane, I assumed he had two amps.
Of course a patch bay would be the best way to go, jump the connectors on the panel ( 1+ to 2+, 1- to2- ).
Don
Michael Webb
« Reply #8 on: February 28, 2011, 12:38:28 am »
Don
michael l
Bennett Prescott
  • This text is personal!
    • Bennett Prescott Dot Com
« Reply #9 on: February 28, 2011, 02:06:19 pm »
Which means the amp sees a 1 ohm load, which it is not rated for, and will limit itself to avoid causing damage to itself (read: considerably less power output than you'd expect).
-- Bennett Prescott
Director of North American Sales
ADRaudio d.o.o.
Cell: (518) 488-7190
"Give me 6dB and I shall move the world." -Archimedes
