Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: Achieving Clean Kick Drum  (Read 20584 times)
Re: Achieving Clean Kick Drum
« Reply #20 on: March 18, 2008, 01:33:32 pm »
[quote title=Michael 'Bink' Knowles wrote on Tue, 18 March 2008 13:27It's a big decision.
[/quote]
Not mention that in most cases (not all) it equates to big cabinets as well (normal horns), in order to get decent low freq response.
dB Audio & Video Inc.
Dennis Malek
« Reply #21 on: May 05, 2008, 01:45:06 pm »
FOUND THE PROBLEM WITH MY PLAYBACK SYSTEM!!!!
First, I would like to thank all of you that helped me by provided food for thought as I worked through this problem.
I decided to first connect up my old single 18" bass horns in place of the LA128's leaving everything else alone.  Sounded like crap with the same poor muddy bass response I was experiencing with the LA128's.
Next, I changed out the pre-amp modules, EQ's, Crossover, etc. and replaced with my old 1980's pre-amp modules 18 db/octive(Audioarts Engineering).  Still sounded bad.
Next, I replaced the two QSC PLX-3402's with my old two QSC MX-1500A's and Presto, THE MAGIC WAS BACK!  Clean sounding Bass response.  Unbelievable sonic quality difference between the PLX and MX series of QSC.  Now I did not have all the power that I want with the MX-1500A, but good quality bass was recognized.  I purchased the PLX-3402's to get the additional power I would need for the LAS128's.
So, with that said, do my PLX-3402's need repair?  Or is this the nature of the beast?
Thanks Much
Dennis
Dennis Malek
Phil Lewandowski
« Reply #22 on: May 05, 2008, 01:50:00 pm »
Dennis Malek wrote on Mon, 05 May 2008 13:45
Thanks Much
Dennis
It may sound really interesting, but there have been several threads here talking about the sound of light-weight switching power supply amps.
Maybe you are another "+1" to the group of people who still like the sound of the "old heavy iron" amps on subs.  I love my RMX1850 on subs so hey... "If is sounds good... It is Good"
Take Care!
Phil
"It is good to be Alive!"
L and L: Live Sound
landllivesound.com
Dave Rickard
« Reply #23 on: May 05, 2008, 02:32:32 pm »
Dennis Malek wrote on Mon, 05 May 2008 11:45
Thanks Much
Dennis
I think there is something else at work here.
Have you tried reversing (un-reversing in this case) the polarity to the 3402's?
Have you tested the polarity on each individual box for miswiring?
Dave
Yorkville dealer
Mike {AB} Butler
    • http://www.3alchemy.com
« Reply #24 on: May 05, 2008, 02:37:33 pm »
AHA! Think we found your real issue! IIRC, the MX series were inverted on the inputs - meaning ring was +.. instead of tip! Here is a recent quote link for Bob Lee of QSC:
http://srforums.prosoundweb.com/index.php/m/318786/33571/0// /360/#msg_318786
Either that, or you're inverting the signal somewhere else.. and the MX is "making good" on the real problem!
FWIW, I have enjoyed PLX amps on subs immensely for the last 9 years, and have found them to be adequate to great, provided you use heavy gauge speaker lines, and also heavy-as-practical AC line is a big plus as well.
Seriously, I don't think you are having a PLX problem,, but rather, something else is inverted in the polarity in your system. Try putting the 3402 back in , and inverting the speaker polarity to see if that may cause a return to life as well.
Regards,
Mike Butler,
Principal, Technology and Operations,
Dascott Technologies, LLC
Dennis Malek
« Reply #25 on: May 06, 2008, 09:34:35 am »
Hello,
Yes I'm making the appropriate compensation for proper phasing as I change in and out the MX series with the reversed Ring Tip Sleeve.
Thanks
Dennis Malek
Dennis Malek
« Reply #26 on: May 06, 2008, 09:40:34 am »
Hello,
I'm compansating for the Ring Tip Sleeve reversal in the MX series.
I have also checked the cabs for proper driver to driver phasing.
I believe I have checked it all.  The PLX-3402's are sonic-ly poor on the low end with comparison to the MX Series.  So much so, that it was easy to tell something was a miss when I first connected.
But Now does this mean they can be repaired?  Or is this just the way they are and not broken?
Dennis Malek
Dennis Malek
« Reply #27 on: May 06, 2008, 09:56:54 am »
Hi again,
Sorry I did not respond completely to your note.
I have been up one side and down the other testing to pin point the problem with my system.
I have confirmed speaker cab. wiring polarities.  I have confirmed stereo right to left channel phasing is correct.  I understand the MX Series signal input reversal on the Ring Tip Sleeve and make the appropriate compensation as I switch the amps in and out.
Changing the amp out was the last thing I did.  I had done everything else previously.
Speaker cable is 12 AWG Oxygen Free Copper and matched lengths 25 FT long.
120 VAC power for the amps is stiff.  Each amp has a dedicated 20 AMP breaker.  I do have 12 AWG 50 FT power leads?  Could this be an issue?
Please keep in mind that this is a Playback System for CD's and NOT live.  I must live with the mix on the CD therefore I chose strong recordings with elevated bass sections and kick drum response for system testing.  When playing the system with the PLX-03402's, the bass response is mud.  Loud as hell, but the clean kick drum is missing.  All I do is replace the two PLX-4302's with MX-1500A's, un-invert the tops, and Presto Clean Bass and Kick Drum.
Somebody please tell me what I'm missing?
I sincerely appreciate any and all input.  In parallel, I'm contacting QSC for their take on this situation.
Dennis
Dennis Malek
Mike {AB} Butler
« Reply #28 on: May 06, 2008, 10:09:39 am »
Dennis,
Thanks for all the information. All I can tell you is that I'm not convinced that the 3402 is the issue.. though, if it does have a defect, borrowing another 3402 from somewhere and testing it in the system should suss that out.
All I can tell you is that 9 years ago, I bought a PLX 1602 to replace a very decent "linear supply" amp (which was still working properly). The difference in bass performance by the 1602 was night and day better!
So, I hear from some folks that SMPS amps like the PLX don't have the bass performance that Heavier Iron and Caps units do. I guess I'm a skeptic in the other direction - I have yet to see where the PLX is dramatically poorer in bass response - unless something else is dramatically wrong..
Regards,
Mike Butler,
Dave Rickard
« Reply #29 on: May 07, 2008, 01:19:22 am »
Mike {AB} Butler wrote on Tue, 06 May 2008 08:09
Dennis,
Regards,
+1.  I use 3002's without the issues you describe here.
Dennis, Kudos for your methodical work so far.
I agree with Mike: find a surrogate PLX to borrow and see what happens before going much further.
Dave
Yorkville dealer
Pages: 1 2 [3] 4 5 6   Go Up
Page created in 0.058 seconds with 20 queries.
