Andy Peters wrote on Tue, 05 February 2008 16:39 |
Richard Rajchel wrote on Tue, 05 February 2008 14:11 | One last thing about "punchy" bass. What the heck does that mean in reality? Most people, including a lot of engineers think to get a great kick drum sound you need subs that go to 20Hz flat(OK I'm exaggerating a little), but that "kick in the chest" feeling is usually in the 60-80Hz range, and in all actuallity the first harmonic of 120-160Hz is where most of that feel comes from.
Agreed. And furthermore, from which cabinet do you get that 160 Hz?
Answer: not the sub!
-a
Yes you do, from the subs, in the form of distortion. At least in front loaded cabinets. I was skeptical about this concept, and/or at least, how much harmonic content a driver adds.
When I got my horn subs back from the builder and was checking them out before finishing the raw wood. I needed to seal and check for leaks around the doors, handles, yada.
While playing 40, 50, 60 Hz test sine waves with the access door open and closed, I could clearly hear harmonics which were not present in those sine waves. Taking the door on and off clearly demonstrated this. When the doors were on the folds in the horn filtered those overtones out.
I believe that's why some folks don't like the "horn sound", the lack of distortion, and prefer gobs of double 18's.
I don't recall what you use for subs at your club, but f you can get horn subs sometime you can verify this.
