Pages: 1 ... 14 15 [16] 17 18 19   Go Down
Author Topic: Subwoofer amps - what are we REALLY hearing?  (Read 34984 times)
Bob Lee (QSC)
Re: Sound Is Subjective
« Reply #150 on: February 14, 2008, 12:13:03 pm »
Ted Olausson wrote on Thu, 14 February 2008 07:34
BTW how can an amp that is stated to have 1000w/8ohm and 1100w/4ohm at 0% distortion hade a DF above 1000!? It should be 1000/2000/4000 watt at 8/4/2 ohm...
Bob Lee
Applications Engineer, Tech Services Group QSC Audio
Secretary, Audio Engineering Society
www.linkedin.com/in/qscbob
"If it sounds good, it is good."
 -Duke Ellington
« Reply #151 on: February 14, 2008, 12:15:37 pm »
Ted Olausson wrote on Thu, 14 February 2008 09:34
I understand the logic behind your misunderstanding but it assumes unlimited current capability in the amplifier. Amplifier DF is related to output impedance which is strictly a matter of device characteristics, internal wiring, and negative feedback, or more specifically loop gain margin. An amplifier's maximum power at lower load impedances, is dominated by current capability and only in the margin to source impedance related output stage losses.  An amplifier's close but not perfect doubling, suggest source impedance effects. Wider divergence from 2x per halving is caused by PS or protection circuitry current limiting output stage.
In an ideal world, there would be a strict doubling of power with halving of load impedance but in practice this requires delivering 4x the amp at 2 ohms as for 8 ohms. Customers have routinely voted with their purchases to support a lesser capability, The marketplace provides what customers are willing to pay for.
 https://www.resotune.com/
Tune it, or don't play it...
Rob Spence
« Reply #152 on: February 14, 2008, 12:28:50 pm »
This is the LF driver I have connected to my DC300 Smile
It is mounted to drive into a sealed enclosure (that is, basket side out).
Driver     Fs     Qts     Qes     Qms     Vas     Re     Prated     Xmax     Diam
L12P48    19.5    0.4    0.44    10    9.52    5    150    0.22    12
Note, I don't claim to understand these parameters and didn't choose them. The speaker cabinet maker did that.
Rob Spence
Lynx Audio Services
E-Mail Rob -at- LynxAudioServices -dot- com
Staying out of trouble
  Is easier than
Getting out of trouble
Your local Whirlwind Dealer
Tim Duffin
Re: Subwoofer amps - what are we REALLY hearing?
« Reply #153 on: February 15, 2008, 09:22:02 pm »
That is not what I was talking about.  A class C "Amplifier" in the sense I am familar is used for unidirectional excitation of particles in water. I think about gyrators for ultrasonic cleaning while you are thinking of gyrators for RF... I never even knew that they had a circuit called a 'gyrator' in RF.
I remember having to assemble a class-c amp in college and look at its output on a scope-- looked like a bunch of humps with some overshoot at zero crossing.
T
« Reply #154 on: February 15, 2008, 10:23:34 pm »
Tim Duffin wrote on Fri, 15 February 2008 20:22
T
A gyrator is an active circuit to synthesize an inductor from resistor, capacitor, and a gain stage. A gyrator could be operated at RF frequencies.
Class C is a resonant amplifier circuit commonly used in RF.
It is you who seems to be confusing the two in your post here .   http://srforums.prosoundweb.com/index.php/m/290789/30842/0// /361/#msg_290789
Tim Duffin wrote on Thu, 07 February 2008 20:09
Fine, Ill use the quote button.
Anyways, the correct answer for my question you did not get. The circuit which is class C is called a "gyrator" and it is not used in audio as per JR's comment.
FWIW, what the output of a class C amp looks like will depend on the rep rate it is excited at.. it could look sinusoidal if excited synchronously with it's resonance. If hit with an impulse it will look like a damped ring .
I am not familiar with your "unidirectional excitation of particles in water" perhaps a pump? Gyrators and Class C have two pretty well defined and unrelated meanings in audio.
I don't doubt there are sundry other devices called gyrators.
for example
Rush developed a variation of this spinning approach called the Gyrator, a horizontal board on which torpid patients were strapped and spun to stimulate blood circulation. (1) An Irish physician developed his own version of this twirling device: O'Halloran's swing (figure 3). Patients were rotated up to 100 times a minute in it. The centrifugal force drove blood to the brain, theoretically treating mental illness and gaining patient obedience. (5)
Laughing
Ted Olausson
« Reply #155 on: February 16, 2008, 09:53:45 am »
John Roberts  {JR} wrote on Thu, 14 February 2008 18:15
Sorry, i was tired. OPAMPS has the same behaviour.
But what other (Known or suspected) factors except DF has a great impact on the relationship between speaker and amp?
« Reply #156 on: February 16, 2008, 10:06:30 am »
Ted Olausson wrote on Sat, 16 February 2008 08:53
I am very much a proponent of amplifiers sounding quite similar to each other as long as operated linearly.
Besides voltage clipping which is more common than many operators suspect, there is running out of current. Especially for an amplifier that doesn't follow the approximate doubling of power with halving the load impedance. That amplifier will current clip before it voltage clips at low impedance loads.
Another poorly understood factor is how loudspeakers, especially when using passive crossovers vary their impedance with frequency. Impedance dips with paralleled speakers could drop quite low at spot frequencies.
The most audible differences are frequency response errors, and added signals (distortion). The tiny differences between amplifiers operating linearly are IMO insignificant in the context of the loudspeakers they are connected too, and room modes, and sources like microphones.
Ted Olausson
« Reply #157 on: February 17, 2008, 08:50:48 am »
John Roberts  {JR} wrote on Sat, 16 February 2008 16:06
Now we are getting somewhere....
But as you say, the linear area doesnt go all the way to clip, it will deviate much earlier than that. Especially with amplifiers with small PSUs and speakers with high levels of back EMF.
That is close to one of the secrets behind the mystical speakers i was mentioning...
Their Re is 5.2 but their Z is 11 ohm within their BW.
(One of the amps is also very close to "2xpower" from DC to 80MHz and has perfect stepresponse, the other is a normal amp)
So are the differences between preamps....
However, the speakers electrical Q is made by the amp, and when you let Qes change then FR also changes.
-and so does the stepresponse.
Protection will also affect the sound much earlier than expected, a perfect example of that is QSC EX vs MXa which is the same amp with different protection, and there is a big difference between them even at -20dB.
There is also a numbergame with distortion, THD% is very inaudible but IM% is almost never stated but highly audible.
BTW, i am not saying that amps are important in comparision to other elements, i am just saying that amps arent perfect.
Andy Peters
    • http://www.latke.net/
« Reply #158 on: February 17, 2008, 01:57:05 pm »
Ted Olausson wrote on Sun, 17 February 2008 06:50
80 MEGAHERTZ?
Why does it need bandwidth out that far, if it's an audio amplifier?
-a
"This isn't some upside down inverted Socratic method where you throw out your best guess answers and I correct your work." -- JR
Alexander B Larsson
Well, some companies display IM distorsion...
« Reply #159 on: February 18, 2008, 06:01:46 am »
Ted Olausson said:
"There is also a numbergame with distortion, THD% is very inaudible but IM% is almost never stated but highly audible."
Well, Labgruppen and QSC certainly displays figures for IM distorsion, at least for the amp models I checked.
Coincidence?  Rolling Eyes
I DO find it interesting that many of the posters really liked the sound and reliability of the "old, continous power, 24/7" amps. Many of you have also clearly said that you ARE willing to compromise on the bass accuracy to get more power and lighter racks.
And I think nobody argues that the D class technology is still in need of more development, since the IM and load matching issues are still not really solved...
/Alexander
Pages: 1 ... 14 15 [16] 17 18 19   Go Up
Page created in 0.062 seconds with 21 queries.
