Author Topic: A weighting vs C weighting  (Read 9032 times)
Vic Wintergreen
    • http://www.vwpsounds.com
« on: March 03, 2007, 01:41:35 pm »
I appreciate the difference between the two response curves, but where is the cross-over point between the two scales. C weighted is designed for higher SPL's and represents the way our hearing adjusts at high levels (correct me if I'm wrong), but at what SPL does sound become a high level.
Mario Salazar
Re: A weighting vs C weighting
« Reply #1 on: March 03, 2007, 10:54:40 pm »
There is a thread on this somewhere in this site.  Try a search.  To answer your question, it is not C but A weighting that "gives an approximation of the actual response of the human ear, as determined by Fletcher Munson."-Yamaha SOundreinforcement handbook.
However, once you get past 100 db the ear's frequency response becomes more linear so C weighing would be more appropriate from this SPL up.
I hope that helps.
Good Luck!
Mario
Mike MacWillie
« Reply #2 on: March 03, 2007, 10:57:19 pm »
Mario Salazar wrote on Sat, 03 March 2007 19:54
Now, is that 100DbA or 100DbC ?
Very Happy  Very Happy
« Reply #3 on: March 03, 2007, 11:09:35 pm »
Mike MacWillie wrote on Sat, 03 March 2007 22:57
I think you both mean dB.   Rolling Eyes
Mario Salazar
« Reply #4 on: March 04, 2007, 12:16:12 am »
 Twisted Evil AAAArg!
I don't know what I mean any longer!Razz
Vic Wintergreen
« Reply #5 on: March 04, 2007, 08:07:04 am »
thanks for the response
i tend to set the foh by ear - if it sounds good - it probably is
i bought a paa2 for measuring levels, as well as checking the mains eq
i am getting some bigger jobs and wanted to show the customers the spl's around the venue, many want it louder, but 110dB at mix point is loud enough i think
i just wondered what was the best scale to use flat/a/c
thanks
Vic
Tom Young
« Reply #6 on: March 04, 2007, 12:49:49 pm »
The choice of weighting networks are of great importance for industrial and legal noise measurements. For example; when you make community/annoyance noise measurements, the local or state statute will provide very clear limits for C and B weighting and also for A-weighting during day and also for evening hours. When you conduct a noise survey, you need to record what weighting you use as well as the location, mounting methods, etc. that were employed. You must also calibrate the meter befor and after the field measurements.
In live sound, there is no clear technical reason to use one versus another, other than if you are relating the measurements to OSHA guidelines, which are A-weighted.
What is always important is that comparative measurements are weighted the same and that when you state SPL you quantify it with the appropriate suffix letter. An un-correlated SPL value means very little in pop music measurements because the bass energy has such a large impact on the measurements.
When dealing with the uninformed, live sound folks can "cheat" the rules (or some poser's cursory knowledge) by using the A-weighted filter so that measurements appear to be lower in SPL than a standard or rule that is based on a Flat or a C-weighted limit. Of course, the opposite trick can also be employed.
So I would not sweat the choice of filters. I happen to use C-weighting when measuring amplified/reinforced pop music and sometimes switch to A-weighting when measuring spoken word or lightly reinforced choir.
Tom Young
Oxford CT
Tel: 203.888.6217
Email: dbspl@earthlink.net
www.dbspl.com
Vic Wintergreen
« Reply #7 on: March 04, 2007, 01:57:45 pm »
Well thats pretty much what I thought. I use the C scale at gigs. However, due to the weighting, the way it is measured, the appears to be nl high-end, as the scale drifts gently down to the right over the high frequencies. I know the highs are there and was just wondering if for a frequency spectrum representation of the sound in the room that A weighted is used, but for an overall SPL reading, the C scale is used. Thanks for your help
Vic
Bob Leonard
« Reply #8 on: March 04, 2007, 02:23:49 pm »
This may be helpful to you. As Tom said above the content will usually determine the weighting used for the measurement.
http://www.engineeringtoolbox.com/decibel-d_59.html
The roar of the grease paint, the smell of the crowd.
Vic Wintergreen
« Reply #9 on: March 05, 2007, 04:26:24 pm »
Ta, funnily enough, just got to the measurement section in Audio Engineering. Always handy to have some other thoughts tho
Page created in 0.061 seconds with 20 queries.
