Elliot Thompson wrote on Sun, 31 July 2005 09:10 |
Hey guys!
I know sinewaves are used when manufacters spec amplifiers. However, I have no idea what Square, Triangle, & Sawtooth waves are used for.
I was reading this, and, it says a square wave offers 50% Duty Cycle.
Would this be more towards a torture test for the amplifier, than loading a 2 ohm load, using sinewaves?
Thanks,
The classic problem when using test signals for evaluating amplifiers or circuitry is knowing what you're looking for and what deviations are important what less so. Regarding square waves for stressing amplifiers, it will simultaneously pull more power from the transformer and power supply while allowing the output power stage an easier time since there is less voltage drop and power dissipation in output devices to deal with.
Square waves have been used for years as a quick and simple way to asses a signal path. Tilt in the horizontal portion of the waveform will reflect LF cutoff. The shape of the rising and falling edges can indicate other characteristics about the design.
In a properly band limited design the edge of the square wave will show a steep exponential curve slowing near the top. This rise time will be defined by the HF cutoff. Note: the rise time for a 1V and 100V square wave will be the same. If instead this rising edge looks like a straight line just tilted a constant amount from the vertical, that suggests the amplifier or circuit is slew rate limiting and not operating linearly. It's not uncommon for such an amplifier to overshoot, ring, and otherwise distort when the square wave stops rising. This overshoot from a poorly designed circuit should not be confused with "Gibb's" phenomenon which is sometimes seen when a very good digital filter removes just the uppermost harmonics of a square wave. While Gibb's looks a little like ringing it's symmetrical occurring just before and after the rising edge (looks like a HF sine wave superimposed on a square wave because that's pretty much what it is, just the missing component not added).
Saw tooth and asymmetrical waveforms are probably more used in old analog synths and analog control circuits. Back in the good (very) old analog days a sawtooth might be used to drive a VCO to create a sine wave sweep. In Synth's they somewhat mimic the harmonic character of some brass and may be more audible wrt absolute polarity but I am not aware of any significant use in testing as a waveform.
The best future test is probably shaped noise and I could imagine a very precise digitally generated noise waveform to excite a circuit or system and a digital receiver that precisely counts the many ways the waveform it receives varied from the reference original. We have historically used sine waves because they were pretty straightforward to generate and analyse. This analysis routinely ignores things like polarity, time delay, phase shift, etc. A very precise review of how a noise waveform gets altered could be pretty instructive but probably be quite difficult to fully interpret the significance of all the results. Audio already has a long history of design excesses and marketing programs based on poorly understood metrics, since amps are getting more alike these days, it's about time to bring in some new tests to misunderstand.
