Author Topic: ported subs proper coupling  (Read 1002 times)
John Barclay
« on: April 01, 2018, 10:35:48 pm »
xxx....sub box with driver lower front, ports upper front  Identical box stacked on top.  Ports together with driver top and bottom of stack OR ports on top and bottom of stack Thx  :)
Re: ported subs proper coupling
« Reply #1 on: April 01, 2018, 10:49:33 pm »
It probably doesn't matter.  How far apart are the ports in the latter scenario?
Sources within 1/4 wavelength will combine, and the bottom octave is what comes out of the port.  At 60Hz that's roughly 4.5 feet...
« Reply #2 on: April 02, 2018, 07:30:14 am »
It depends on how high the cabinets are run, the tuning freq of the ports, the size of the cabinet etc.
It may or may or may not matter-based on the answers.
But to be safe, I would put the ports on the outsides, drivers together.
This way the drivers have a better chance of coupling at the higher freq, and since the ports are tuned at the lower freq, the wavelengths are longer, so they can be further apart and still couple.
It is all about wavelength size and spacing.
Page created in 0.069 seconds with 23 queries.
