Author Topic: Need ip rated outdoor wireless speakers  (Read 1391 times)
eric lenasbunt
    • Bunt Backline Event Services, LLC
« on: April 04, 2017, 12:12:16 am »
I am working on a park project that basically wants distributed audio throughout the park on several light poles. There is a power outlet at each pole but no good way to run speaker wire. Are there any wireless active speakers that may be right for this solution? Most positions are <500' from control room with nice clear lines of site
Re: Need ip rated outdoor wireless speakers
« Reply #1 on: April 04, 2017, 10:24:08 pm »
Old school "carrier current" broadcasting?  Also make sure the power available is 120v, not 277v. (don't ask how I know).
Caleb Dueck
« Reply #2 on: April 05, 2017, 06:48:11 am »
Powersoft DEVA speakers may work, they are designed for these types of applications.
Craig Hauber
« Reply #3 on: April 05, 2017, 10:02:36 am »
Not sure about all-in-one products, but you could mount a properly-rated enclosure with an amp and receiver and use one of the many passive speakers available in the weatherproof market.
https://www.technomad.com/products/powerchiton/
Your electricians can also install a small step-down transformer in it's own box too if the light power is 277V or higher as Tim mentioned.
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Robert Healey
« Reply #4 on: April 05, 2017, 11:38:47 am »
Is it mission critical - enough to spend a chunk of money on? If so:
http://www.xirium.net/en-us#intro
plus a rated powered speaker or the Technomad amplifier mentioned previously.
eric lenasbunt
« Reply #5 on: April 19, 2017, 08:06:37 am »
Thanks guys. There is a light and a 120v standard gfi on each post. Figuring the electrician would wire us a box at the top of the pole off that circuit.
I'll check those products.
Thanks!
Page created in 0.084 seconds with 24 queries.
