Author Topic: RF coordination simultaneous example using IAS and Workbench  (Read 17524 times)
Pete Erskine
    • Best Audio
« on: September 02, 2015, 09:35:01 pm »
Here is an expansion on my videos about IAS and WB.
It is divided into 2 - 12 minute videos.
Part 1
Part 2
« Last Edit: September 02, 2015, 11:03:48 pm by Pete Erskine »
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
Neil White
Re: RF coordination simultaneous example using IAS and Workbench
« Reply #1 on: September 03, 2015, 09:56:18 am »
Hi Pete,
Thanks for the detailed videos. I think the most interesting thing is the noticeable difference in the equipment profiles between the two pieces of software. The WWB6 profiles seem to be more conservative than the IAS ones. Are these settings something that can be calculated from an equipment's spec sheet?
Neil
Pete Erskine
    • Best Audio
« Reply #2 on: September 03, 2015, 10:13:30 am »
Hi Pete,
Neil
NO, these are arbitrary settings set by the software designer.  Not much to do with eq specs.
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
Jens Palm Bacher
    • Lydfabrikken
« Reply #3 on: September 04, 2015, 02:43:30 am »
Well you could if the specs showed the intermodulation attenuation  etc. It is clear that a Sennheiser 5212 transitter in "low intermod" mode will have better specs than a cheap Shure unit, but it is not easy to read from the spec sheet.
peter dakin
« Reply #4 on: September 05, 2015, 07:08:38 am »
great videos Pete.
Can I ask what device your using for scans, does this pump out a file format compatible with WW6 or do you need to convert it?
Cheers
Henry Cohen
  • Westchester Co., NY, USA
« Reply #5 on: September 05, 2015, 08:12:24 pm »
Whereas it would be nice to know the IM suppression number, it's really kind of irrelevant: Whereas one device (the transmitter) may not be producing the IM product, another device might be; the preamp in the antenna, the multi-coupler or the receiver front end. The IM software programs are merely pointing out the math of potentially problematic frequencies and in no way negates the need for a "war game" or other walk test.
Henry Cohen
Pete Erskine
    • Best Audio
« Reply #6 on: September 05, 2015, 08:57:11 pm »
Scans are from TTI.  More detail on how I did it can be found at http://www.bestaudio.com/spectrum-analyzer-setups
Normal TTI scans can be used in WB as long as you edit out the Headers using a text file.  All of the scans listed on my website have the headers removed and can be imported into either IAS and WB.
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
Jason Glass
    • CleanWirelessAudio.com
« Reply #7 on: September 05, 2015, 11:31:18 pm »
With this always in mind, I often adjust the intermod bypass window settings in IAS to generate more usable frequencies in large channel-count coordinations, gradually reducing the bypass bandwidths as required.  It's less risky than completely abandoning triple-beat calculations.  The risk can be further mitigated by setting and adhering to a strict band plan, where like-type equipment is assigned to specific areas of spectrum, with large guard bands between the different types.  This technique is also a reason that I try to stay away from broadband RX antenna amplifiers if possible and use passive higher gain antennas on the front end.
« Last Edit: September 06, 2015, 10:29:55 am by Jason Glass »
Henry Cohen
« Reply #8 on: September 06, 2015, 09:15:51 am »
This is technique is also a reason that I try to stay away from broadband RX antenna amplifiers if possible and use passive higher gain antennas on the front end.
I can't stress enough the validity of this statement. Amplified antennas and other in line preamps cause far more problems than they solve 99% of the time. Their use has limited applications, and not has a band-aid for other inadequate system implementations.
Henry Cohen
Neil White
« Reply #9 on: September 06, 2015, 03:22:36 pm »
It is interesting that some manufacturers seem to market active antenna as their recommended product for radio mic receive antenna. Is the correct application to make up for cable losses, not to compensate for rf path loss?
Are there any rules of thumb for how far to keep transmit and receive frequencies separated by in a spectrum band plan?
Page created in 0.042 seconds with 23 queries.
