Pages: [1] 2 3 4   Go Down
Author Topic: aux fed subs  (Read 11060 times)
Bob Kidd
aux fed subs
« on: January 31, 2014, 12:37:29 pm »
Based on previous post on this subject I decided to try and set up at aux fed subs using available crossovers and my sound craft so compact. I'm using dbx drive rack pa on tops and dbx 223 on subs. Routing through aux 14 on sound craft. Set crossover on 223 at 87hz and driverack at 90hz. Other than plating programmed music I have not used live yet. Given the different crossovers am I creating more issuses than solving?
Patrick Tracy
  • Boulder, CO, USA
    • Boulder Sound Guy
Re: aux fed subs
« Reply #1 on: January 31, 2014, 12:48:51 pm »
No way to know for sure without measuring the response. What matters is the actual acoustic crossover. The filters are just a means to that end.
Scott Carneval
    • Cenero Audio Visual
Re: aux fed subs
« Reply #2 on: January 31, 2014, 01:17:35 pm »
There's a 10+ page post on this topic from a week or so ago.
Jason Lucas
  • Hillsboro, OR, USA
Re: aux fed subs
« Reply #3 on: January 31, 2014, 02:06:53 pm »
If you're ok with running your tops mono, you could run both tops and subs off one unit and then you'd have the same crossover frequency.
Just an idea.
There are three things I hate: Harsh highs, hollow mids, and woofy bass.
Bob Kidd
Re: aux fed subs
« Reply #4 on: January 31, 2014, 03:09:18 pm »
Just an idea.
Thanks Jason, right now I have it setup as subs in mono and tops in stereo. This could be an option. I will more than likely go back to the traditional setup for now until I get this fine tuned. I did read through previous post which is why I started setting it up but was concerned based on crossovers I have available and that I do not run Smaart that I maybe creating more of an issue than helping clean up low end. Will look to upgrade crossover. Thanks
Greg_Cameron
    • Cameron Pro Audio
Re: aux fed subs
« Reply #5 on: January 31, 2014, 03:23:15 pm »
I've been running a DSP (XTA DP448) for my tops and an analog crossover for my subs for years (currently the dbx 223XL because my old BSS crapped out). There's nothing wrong with doing it that way and it works great. The potential issue with alignment is that the DSP introduces some latency relative to the analog sub processor. Since my tops are flow and the subs on the floor, it doesn't matter. If I were to stack the tops on the subs, I'd add the delay to match the tops at the aux output on my digital desk if was required.
Cameron Pro Audio
Bob Kidd
Re: aux fed subs
« Reply #6 on: January 31, 2014, 03:52:32 pm »
Thanks, this helps greatly. I do stack mine and would need to determine how much delay is needed.
Patrick Tracy
  • Boulder, CO, USA
    • Boulder Sound Guy
Re: aux fed subs
« Reply #7 on: January 31, 2014, 04:01:28 pm »
Since the tops normally need to be delayed to the subs anyway the inherent latency of the DSP is a change in the right direction.
Bob Kidd
Re: aux fed subs
« Reply #8 on: January 31, 2014, 04:33:19 pm »
OK, well then I have been running all wrong then. In my traditional setup I never delayed the tops to the subs.
Patrick Tracy
  • Boulder, CO, USA
    • Boulder Sound Guy
Re: aux fed subs
« Reply #9 on: January 31, 2014, 05:14:39 pm »
I seldom delay my tops for my little setup. But I do tend to place my subs forward of the mains a little.
Pages: [1] 2 3 4   Go Up
