Author Topic: Electro-voice EVA  (Read 8519 times)
Chuck Fudge
Electro-voice EVA
« on: April 27, 2010, 01:29:12 pm »
Has anyone demo'd/installed EVA line array components?  I would like to hear honest opinions regarding sound quality, ease in installation etc.
in advance, thanks for the responses
Chuck Fudge
Technical Director
Braden Auditorium/Bone Student Center
Martin Morris
Re: Electro-voice EVA
« Reply #1 on: June 18, 2010, 09:29:22 pm »
Ethan Wetzell of EV/Bosch lurks here. He could well know of users  or an installed system local to you.
Worth a shot, Search for Ethan Wetzell.
Cheers
Martin
Dave Sturzenbecher
« Reply #2 on: June 18, 2010, 09:37:16 pm »
I was able to listen to the in the Infocomm EV Demo Room.  Needless to say...i am a fan.  It is pretty remarkable what they can do off of two amp channels, and the sound, was very good, very smooth.
One thing I would like to point out is that you really need to do your homework before you hang these.  With only one amp channel feeding a whole array, there is no remote controlled DSP setting that can shade the array properly. Attenuation is all performed via plug in modules in the back of each cabinet so if you need to adjust these, you need access to the back of the cabinets.
Ethan Wetzell (EV)
« Reply #3 on: June 21, 2010, 09:15:16 am »
Indeed I do lurk here, I just didn't want to jump in since Chuck was asking for independent reviews, and I may not be considered neutral when it comes to the matter.
To Dave's point about "doing homework", simply use the EVADA software to make your model and predictions in advance (as you should with any line array), and you're good to go:
http://www.electrovoice.com/sitefiles/downloads/EVADA_V2.2A. zip
Sincerely,
Ethan Wetzell
Product Manager Electro-Voice Signal Processing
Bosch Communications Systems
Chad Costanzo
    • http://www.PyxisIndustries.com
« Reply #4 on: July 13, 2010, 12:36:32 pm »
I agree that they sounded great in the demo I heard as well and look great for the install market.  I actually have some spec'd in a quote right now and we will see if it happens and if it does I get to play with them and learn more.
Chad Costanzo
President
Pyxis Industries
888-PYXISAV
Chad@PyxisIndustries.com
http://Http://www.PyxisIndustries.com
Dealer: Elation, ADJ, Audix, Shure, Audio Technica, EV, Midas, KT, Heil,  Global, Avant, Antari, Hosa, & MORE
Pete Lee
« Reply #5 on: February 14, 2011, 01:05:41 am »
Hi Ethan,
Which Amps would you recommended for 2 arrays (4 each)?  Will 1 CPS 2.12 MK II good enough to drive them?
From my calculation 1200W @ 4 OHM will => only 300w per module.  A bit short of the Continuous/Program/Peak (350w).
How about other brand of power map, such as QSC..etc?
Thanks!
Page created in 0.035 seconds with 18 queries.
