Hi Walt,
this is what I found on the web...
Regards,
Leon
1)
High power handling. 2,000 to 3,600W RMS, depending on the application. 2) Flat response. Both drivers are flat +-1dB to 500 Hz. Not typical of high power subs... but that way by design. This extend response allows the drivers to be used with a wide array of crossover frequencies and slopes.
3) Very low power compression. Inaudible for most applications.
4)
Super linearity. 100% linear BL product for +18mm of travel in EACH direction. Proprietary spider and precise details in the surround provide exceptional mechanical linearity and smooth overdrive characteristics.
5) Extremely low distortion, below the threshold of audibility for most of the output envelope.
6)
We are experts in Acoustic Power Density. These drivers have the highest low frequency output ever obtained in standard 15" and 18" sizes thanks to 78mm of travel, high power handling and low power compression. In many applications, one driver can be used where two are being used now.
7) Relatively simple and bullet proof design. We believe in the KISS principle.
Parameters optimized for very low frequency performance. These drivers can still be used to generate ludicrous amounts of "standard" bass (50-100 Hz) if needed, but they have been designed to excel at very low frequencies, requiring little or no equalization for many properly designed subwoofer applications, maximizing the power available from amplifiers.
18"
Sd = 0.108 m^2
Cms = 106.6 um/N
Vas = 174 liters
Re = 6.2 ohms
Mms = 305 g See Below
Fo = 28.2 Hz
BL = 23.3 t*m See Below
Qe = 0.62
Qm = 8.90
Qt = 0.58
SPL = 90.5 See Below
The data above is derived from the impedance curves. Note that the Mms values above includes ALL of the acoustic mass as well, which is substantial in subwoofers. In addition, the actual BL values for these drivers is about 8% higher than the parameters above. As a result of both of these measurement artifacts, the calculated SPL 1W/1m dB's are lower than actual SPL's by 0.5 to 1.5dB. We have provided the actual SPL's in the data above.
Overall Diameter = 462mm
Mounting Holes = (
6.4mm holes on a 441mm B.C.D.
Cut Out = 425mm ; Maximum thickness of baffle at cut out = 1.25" (32mm)
Weight = approximately 44 Lbs.
Depths assuming "drop in" or "standard" mounting:
Mounting surface to back of driver = 224.50mm
Mounting surface to top of surround roll, full excursion = 48mm
Diameter for the depth above = 345mm nominal. Suggest you use 355mm to account for the cumulative errors associated with cabinet and grill errors... depending on the application
