I have a question for users of PL380 amps.
I have an event coming up where I will be using two PL380s and a PL340. One of the PL380s will be run at 2 ohms per channel to power four 2X18" subs and the other will power the LF section of four 2X15" cabinets. The 340 will be run at 8 ohms per channel for the HF drivers of the 2X15" boxes.
I have limiters and processor settings already set for the boxes.
My questions for those that have used their PL380s at 2 ohms per channel. How has it worked out so far for you. Have you been happy with the sound of them at 2 ohms? Did you find yourself running into the amps clip limiter a lot or did they exhibit lots of clean headroom.
Lastly, How was the current draw at 2 ohms. The manual states 1/8 power at 19.1 Amps. Was that similar to your experiences or did you find them to be more or less efficient then that?
This particular event is one in which my guys are doing it and I will not be on location so I want to get as much info as possible prior to the event.
I have tested the PL380 on the subs with a CD and found them to sound pretty punchy but I didn't get to really push it and probably will not have the opportunity to really put it through the paces prior to the event.
Thanks a bunch, Ryan
