Author Topic: BassBoxPro 6 Software  (Read 8783 times)
Antone Atmarama Bajor
Re: BassBoxPro 6 Software
« Reply #10 on: June 04, 2011, 12:36:41 am »
Hey Lance, do you rely soley on manufacturers T/S specs or do you measure them yourself? I find supplied specs to be off in quite a few cases.
Depends on the manufacturer and how good their specs are.  I like that eminence gives a response curve up above bass region, for most of the drivers.  I've never spent the time trying to generate my own.  That takes well calibrated test equiment, and repeatable measurement conditions.
Lance Qu
  • Engineer/Sales
« Reply #11 on: June 07, 2011, 02:01:28 am »
Latest driver database update is 2/23/10. You can enter the TS parameters (either measured directly or from manufacturers' websites) for other drivers and save them into the database.
http://www.ht-audio.com/pages/BassBoxPro.html
thanks George, the link is very helpful to me ,thanks very much
Lance Quinn
Jesus always loves us;
Let music comfort your pain...
http://www.icespeaker.com
Lance Qu
  • Engineer/Sales
« Reply #12 on: June 07, 2011, 02:07:18 am »
The "Peak" or longest Group Delay normally happens at Port tuning.
the longest group delay is 18msec at 31.8hz
Lance Quinn
Lance Qu
  • Engineer/Sales
« Reply #13 on: June 07, 2011, 02:12:12 am »
Hi Jeremy, i got most of the T/S specs from manufacturers' web. some i measured myself ,like the depth or lenght of transducer, every manufacturers' supplied information ,not enough.
Lance Quinn
Lance Qu
  • Engineer/Sales
« Reply #14 on: June 07, 2011, 02:17:37 am »
Hi Antone, i have a question, may i use the BassBx Pro 6 for full-range speakers ??  I want to try the eminence HF for my 12inch ,  i like the eminence 2002 HF transducers. what do you think BassBox Pro6 for designing full-range
Lance Quinn
Art Welter
« Reply #15 on: June 09, 2011, 03:24:46 pm »
Lance,
BassBox Pro 6 will work fine for designing the cabinet and port dimensions for a top cabinet, but will not predict port resonances, cone breakup and upper peaks that the speaker will have.
In a sub, the port resonances and cone breakup are well above the passband, in a full range box the port resonance can easily be in the passband, and cone breakup also within the passband if too high a crossover is chosen.
I sent a PM to you regarding PSD2002 I have for sale.
Art Welter
« Reply #16 on: June 12, 2011, 09:57:44 pm »
The 2002 has a roll off a little lower than I would like in the HF, the 16 ohms may or may not help in not needing as large of a pad to match spl's but making a crossover that actually performs well requires measurement and listening tests.  One can use the xover design software as a starting point but you will seldom get what the xover software predicts in the real world.
    I really nice high frequency transducer that I is the B&C DE250 or what ever the newest version of that transducer is, it has nice linear extended HF response.
As far as designing a full range box I've done some 3 way boxes, some of which predicted very nicely and others which had unexpected consequences due to baffle diffraction effects.  You can find a good starting point but like Art said cone breakup and some other things can't be predicted with bass box.
     Or polar behavior at xover.
I do think that a 2 way with a single twelve will be better than a single 15 but I think its still a little bit of a compromise with the low cut of the 2002 compression driver.  I normally try to not xover at the low cut, imo compression driver horn combos sound bad if they are driven the absolute low cut.  And I think 12's start beaming above 900Hz.
     But its all a compromise at some point, and its all about what compromise works best for you.
« Last Edit: June 12, 2011, 10:11:24 pm by Antone Atmarama Bajor »
« Reply #17 on: June 12, 2011, 10:14:37 pm »
Lance,
Art Welter
I was playing with a miniature bandpass design that predicted out of band port resonances around 10dB louder than the pass bands response.
And they where pretty accurate to what Bassbox predicted.
I think the only way to tame it would be to use some parametric cuts on a dsp controller.
Art Welter
« Reply #18 on: June 13, 2011, 02:49:15 pm »
Lance,
Art Welter
Interesting. I have not actually used Bass Box Pro, just have looked at lots of charts generated by the program, and had never seen any port resonances shown. Wrong ASSumption on my part that the program does not show port resonance.
« Reply #19 on: June 16, 2011, 12:50:40 am »
Yah its a little tab you can turn on, and I must say I have seen close to predicted resonances most of the time.
I don't know if I have any of the sweeps still But the resonance actually resembled an asymptote on the tef sweep, as predicted in bassbox.
     I'll have to look at it again I think it has a little baffle prediction, and a little room size prediction (for cars and small rooms I think).
Its a slick little program.
Page created in 0.048 seconds with 21 queries.
