True, and the two positions are 1.4v and 26dB, so they aren't exactly consistent with their units. For what it's worth the 1.4v setting has a gain of 32.1dB on the CE2000 and 30.5dB on the CE1000.
[Edit] And since it's the CE4000 being discussed: 39dB and 33.8 are the gain figures for the .775v and 1.4v settings.
Actually they being consistant. The VOLTAGE rating is the required input voltage to achieve full output. Yes the gain of the amplifier will change with the output "wattage".
The 26dB gain position mean that that as long as all the amps in the system are set to this position, it will provide 26dB of gian over the input signal.
Which one you use depends on how you want your system to 'setup".
