Trying to help with no idea of the layout of the platform (it's size and orientation to the room) and where there are rigging points (etc) is not possible. Other factors include praise/worship style, acoustic info about the space, ambient noise levels, behavior of band, etc, etc.
You cannot simply choose a loudspeaker and hang it without great risk that the load will not be supported over time and this can result in someone getting injured, maimed or killed. Suspension of loudspeakers (as well as lighting and projectors) requires a structural engineer. The fact that you are a church and/or a small church does not exempt you from this responsibility.
Designing a stereo sound reinforcement loudspeaker system is a non-trivial, very complicated task. You do not simply put two loudspeakers up to either side.
If you continue to try to do this on your own and with what help folks here may offer I can guarantee you that you will end up with a less than good sound system and one that also may be unsafe.
What do you do ? Hire a qualified design consultant or design-build contractor who specialize in sound systems for HOW and have proven track records.
Do it right, do it once.
