Author Topic: SQ/AR2412 Traces  (Read 1804 times)
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
SQ/AR2412 Traces
« on: July 19, 2018, 10:05:40 am »
Finally got around to getting traces on A&H's SQ/AR2412.
Looking at the AR2412 traces I might see why SQ sounds slightly better than the 48kHz GLD/Qu/stage boxes. The phase wrap @ 20kHz & unstable performance at 20kHz is interesting. Not sure how performance hindering it is, but it's something.
SQ - Local - Main L - 0.52ms (Purple)
SQ - TB - Main L - 0.42ms     (Teal)
SQ - Local - Mix - 0.48ms      (Red)
SQ - Local - Grp - 0.44ms      (Blue)
AR2412 - SQLocal - Out - 1.13ms (Gold)
AR2412 - SQTB - Out - 1.02ms     (Green)
AR2412 - Local - Out - 1.48ms      (Red)
AR2412 - Local - SQOut - 0.88ms  (Purple)
Note, times are relative; I have no idea what the delay of my measurement setup is.
Scarlet 2i2 1-out > DUT
Scarlet 2i2 2-out > 2-in
DUT > Scarlet 2i2 1-in
1-out > Scarlet 2i2 2-in
« Last Edit: July 19, 2018, 10:16:14 am by Nathan Riddle »
Mark Wilkinson
Re: SQ/AR2412 Traces
« Reply #1 on: July 19, 2018, 02:53:20 pm »
FWIW, I've recently found when trying to use Smaart for purely electrical measurements, that it seems kinda impossible to know what's really going on with phase of the DUT at the very end of the spectrum.
Because I think any measurement also includes sound card non-linearity.
And maybe even sample timing zero points with sound card and DUT don't completely line-up.... I dunno...
I just know that even at a 96kHz sampling rate, 1 sample is worth 70 degrees of phase at 20kHz.....so how good can 20kHz phase measurements be when both the souncard and DUT are digital and when there's no sync lock between them?
It's like there's a 35 degree +/- average error at 20kHz built in, if I'm thinking straight.......
Plus, Smaart doesn't to my knowledge allow sound card calibration for the card's non-linearites.
Coincidentally, yesterday I asked on the Rational Acoustics support forum, if there's a way to incorporate a sound card calibration.
I had been measuring some amp outputs and all the amps were showing the same tailing response up high.
So I checked the soundcard itself with REW. (which does  soundcard calibrations)
Turns out, the tailing was in the sound card (UMC404) and not the amps.....
Which means the tailing would show in acoustic measurements as well doesn't it ?
Nathan Riddle
  • Niceville, FL
« Reply #2 on: July 19, 2018, 03:38:31 pm »
You might be onto something. And I won't pretend I know anything about all this. But my thought process is as such:
Purely considering just the results of measurements we can easily see 20kHz changes in phase/magnitude of small (in the degrees) by moving the mic minutely. How is that possible if 1 sample is truly 70 degrees @ 20kHz?
20kHz is extremely flat for a straight wire, and less so for various components, amps being some of the flattest and sound boards exhibiting some small phase distortion/difference.
Specifically the AR2412 (older purple one) measurements:
Using no smoothing or averaging one can pretty quickly discern the differences (noise floor maybe) in magnitude at 20kHz I think that's what I felt would be most noticeable audibly. Since who can tell there's a phase wrap at 20kHz when moving an inch changes the relative phase completely?
I dunno either...
Mark Wilkinson
« Reply #3 on: July 19, 2018, 05:01:33 pm »
Hi Nathan, I stand ready to be corrected too ...you ask a good question..
Here's my thinking... first, pls check my numbers.....
96kHz sampling means 1 sample (1 sec/ 98,000) =0.0104 ms.
20kHz sine wave has a 360 degree period of (1 sec /20,000) = 0.05ms.
So, 1 sample @ 98kHz  for 20kHz = (.0104/.0500)x 360 =75 degrees.
While we're at it, 75 degrees of 20kHz = (1130ft/20,000)x(75/360)= about 1/8 inch distance.
Ok, it seems to me, Smaart's time resolution has to be thought of as having two aspects...
One is the timing relationship, mathematically determined that probably? is continuous between the reference signal and the measurement signal.
But is seems that timing relationship is bound to being calculated off a discrete number of processing samples, represented by the delay finder time to the nearest sample.   (Note you can't adjust the delay finder less than 1 sample's worth of time)
So a small 1/8 mic movement can make for a small phase movement, because the math is continuous around whatever discrete time difference has been determined. But Smaart has to recalc constantly to the nearest sample, when more than a sample's movement is detected. So it's kinda a hop and calc situation....
I've often seen on traces that tail up or down at 20kHz, that I simply can't get zero phase at 20kHz using MTW and it's 48kHz sampling.
Bumping delay finder between two samples....it's either tail up, or tail down...unless I move the mic a tiny bit, and get lucky on the hop location.
Did I make any sense at all ?
edit: changed 98kHz typo to 96kHz
« Last Edit: July 21, 2018, 10:04:10 am by Mark Wilkinson »
Hayden J. Nebus
  • Richmond, VA
« Reply #4 on: July 20, 2018, 09:38:27 am »
If you allow device aggregating, you can snap a TF of your I/O device with a loopback cable (OP to IP) and stim with the analyzers onboard generator, selecting the Gen as the reference. On v7 for me this always devolves into clock slip, but it works long enough to get a good TF of op and ip stages together. If they ain't flat enough for ya, use other IO.
Mark Wilkinson
« Reply #5 on: July 20, 2018, 12:31:39 pm »
Hi, thx. But  I'm not understanding... what do you mean by 'device aggregating'?
And how do you select Gen as reference?  I only see the Input Channels of my soundcard as available choices....either v7 or v8..
« Reply #6 on: July 23, 2018, 09:00:25 am »
Adjustments to time within software is limited to a resolution of 1 sample period.
Marc Sibilia
  • Princeton, New Jersey
« Reply #7 on: July 23, 2018, 09:31:49 am »
REW will do sub-sample alignment of impulse response, so it will be better for amplifier/mixer/processor measurements if you are concerned about phase at high frequency.
Quote from the manual:
The Sub-sample timing adjustment selection controls whether REW adjusts the impulse response timing to resolution below a single sample when setting t=0 at the IR peak or using the other channel as timing reference. Sub-sample timing adjustment requires a resampling of the impulse response to perform the adjustment, which slightly raises the noise floor of the measurement - however the increase is far below the noise floor of a typical acoustic measurement and sub-sample adjustment provides more accurate phase information at high frequencies.
Marc
« Last Edit: July 23, 2018, 09:36:24 am by Marc Sibilia »
Mark Wilkinson
« Reply #8 on: July 24, 2018, 09:09:39 am »
Marc
Yes, I've been using REW for such measurements for that reason.
But I had forgotten the VHF phase accuracy is due to the sub-sample option.
Thx for the reminder.
Nathan Riddle
  • Niceville, FL
« Reply #9 on: July 24, 2018, 10:21:50 am »
I think I found what you are talking about.
http://www.rationalacoustics.com/forums/showthread.php?1094-ref-to-gen-delay-time-problems
"Transfer Function measurements can also be referenced internally to Smaart's signal generator by enabling "Allow Multi-Device Transfer Function" option on the Transfer Function page of the main Options dialog and selecting the Generator as your reference signal source. In practice there are a few caveats to doing this, again mainly associated with delay times. For one thing, the latency of the measurement system from the output to the input becomes a factor in measuring absolute delay times. (This is generally not a factor when actively actively recording both input signals.) Another is that the latency through the measurement system may not be consistent from one measurement to the next, meaning you may need to measure the delay again each time you stop and restart the measurement and/or the signal generator. And finally if the measurement signal input and the output used to stimulate the system under test are not identically clocked, then the reference delay time will be subject to drift while measuring, and not just when restarting the measurement."
Page 100 in v7 manual:
http://www.rationalacoustics.com/download/Smaartv7UserGuide.pdf
Page 112 in v8.
I'll have to try that and see.
Mark, good discussion. I agree with your math. 1/8" seems about right.
Does that mean that we can't measure up to 20kHz phase response accurately? Or am I missing something with the REW discussion?
Can someone explain in more layman's terms how subsampling works? Is it simply using interpolation between samples to obtain the expected value?
Page created in 0.05 seconds with 23 queries.
