Author Topic: Questions for Soundcraft SI Impact owners/users  (Read 1136 times)
John T. Cotton
    • Frugal Audio
« on: July 11, 2018, 08:02:48 pm »
I just bought a b-stock Soundcraft SI Impact.  It was a good deal, and it seems like a nice little console for small personal gigs.  I haven't really had my hands on any of the Soundcraft digital consoles.  My regular gigs are mostly Midas or Yamaha.  So I'm hoping any Impact owners could let me know if the things I'm seeing are normal behavior for the console, or potential problems.  It will be a while before I can take it on a gig, so I need to give it a pretty good work out & inspection at home. Never having touched one before, I just don't have any basis for comparison.
Does your Impact run warm?  Mine seems to run fairly warm, across the entire rear of the console.  Not burning hot, but warmer than I would expect.
Main screen "Adjust" encoder- is yours responsive/accurate.  When I change parameters with this encoder, it seems to lag a bit in response, and makes pretty big jumps in value.
Channel LCD- how visible are your channel meters?  Are they easily adjusted through the preferences menu?  I'm having trouble making the channel meters in particular stand out.  Brightness seems to adjust okay through the menu, but contrast seems to jump from minimal to completely blown out with very little finesse in between.
Gain structure:  is -18dBFS nominal on this console?  Setting the oscillator to 0dB and assigning to a buss seems to result in a slightly lower than -18 level.
John T. Cotton
www.FrugalAudio.com
Will Knight
Re: Questions for Soundcraft SI Impact owners/users
« Reply #1 on: July 11, 2018, 08:27:10 pm »
Sounds like you may need a firmware update.  Have you checked and applied the latest firmware to the desk?  Check the SC site as Ver 2.0 solves a number of issues that surfaced in the early models.  Here’s a link to the SC website for the firmware
https://www.soundcraft.com/en-US/softwares/si-impact-2-0-firmware
I’ve had the Impact for 2 years running and have not experienced any of the issues you’re referring to so far.
John T. Cotton
    • Frugal Audio
« Reply #2 on: July 11, 2018, 08:46:49 pm »
It's on v2.0 build 004, which seems to be current.  I can try reloading it.
John T. Cotton
www.FrugalAudio.com
John T. Cotton
    • Frugal Audio
« Reply #3 on: July 11, 2018, 09:17:20 pm »
I reflashed the firmware, and wiped the internal SD card memory.  The Contrast on the channel LCDs definitely seems out of wack.  It's limited to values between 35-39.  Is that normal?
John T. Cotton
www.FrugalAudio.com
Will Knight
« Reply #4 on: July 11, 2018, 10:05:47 pm »
Definitely not normal.  I'll pull my Impact out from Storage tomorrow and run through a series of test on the points you've raised & confirm the results you should be expecting. You mentioned B Stock.  The most common issue that surfaced in early runs of the Impact was a resistor problem at the incoming AC line.  It's a free repair by SC but you'll need to check your unit serial unit with SC Support to confirm it's already been fixed (reason for B Stock) - or needs to be sent in for repairs.
I would also recommend a search here on the forum where the Impact, it's capabilities, etc. has been discussed by members at length.
Lee Douglas
  • 47.662615, -116.756954
« Reply #5 on: July 11, 2018, 10:06:59 pm »
Both of mine and the others I've walked up to seem match this description.  It does run a little warmer than I expected it to, but even in quite warm weather it didn't seem to get much warmer.  Just make sure that both front and rear vents are clear and it should be fine.  I haven't noticed anything odd about the encoder(s), but will watch for it next time.  The LCD contrast adjustment is extremely lame and never does adjust to bright and clear to where I would expect it be able to.  It's much better in a dark room, but it's not like they were stuck using old worn out displays from the '80's.  My friend's Vi looks extremely bright and sharp.
This space for rent
John T. Cotton
    • Frugal Audio
« Reply #6 on: July 11, 2018, 10:19:00 pm »
Thanks for your help gentlemen.  I have emailed both Soundcraft, and the vendor I got the console from.  I have searched the forum for info in the console, part of what lead to my purchase decision.  I'll update the thread as I learn more.  Hoping I didn't get a lemon, as I've been looking forward to having the console.
John T. Cotton
www.FrugalAudio.com
John T. Cotton
    • Frugal Audio
« Reply #7 on: July 12, 2018, 08:39:10 am »
Response from Soundcraft:
Subject:
RE: [EXTERNAL] Technical Support
Date:
Thu, 12 Jul 2018 08:58:33 +0000
Hi John,
Both of these things are absolutely normal.
Thanks!
Balázs Sólyomi
Back Office Engineer
The following was received via the Soundcraft website:
Name: John T. Cotton
Product: Si Impact
Serial: xxxxxxxxxx
Message/Details/More Info, etc...
Is it normal/typical for the channel LCD contrast setting to be limited to values between 35 & 39? Also, is it normal for the console to be notably warm to the touch across the rear/back? Thank you, John T. Cotton
John T. Cotton
www.FrugalAudio.com
Helge A Bentsen
  • Oslo, Norway.
« Reply #8 on: July 12, 2018, 10:20:22 am »
LCD contrast is weird on these consoles. Feature set is promising, but fails on all the little details. Very «Soundcrafty».
I had one for years, traded it for a M32R when I finally got fed up with it.
Mixing tip: never move your master fader below 0dB, the master bus can’t handle a lot of hot channels going into it and the master meter is post fader. Keep it at 0, send L/R to a matrix and use the matrix fader as level control.
Dave Pluke
    • BIGG GRIN Productions
« Reply #9 on: July 12, 2018, 10:04:43 pm »
In my experience:
1)  My Si Impact also runs warm.
2)  My Encoder is a bit slow - but not jumpy.  You have to settle into the rhythm of this console.
3)  Haven't run mine in bright daylight conditions.  LED's seem fine inside rooms.
4)  Can't answer that question - sorry.
I, too, was lured by the low price of a B Stock (reportedly, Factory Refurbished) Impact.  The one I received randomly shut off.  At first, I thought it was me being too twitchy on adjustments, but I could just leave it running with music playing through and it would shut off after an hour or so.
Fortunately, I purchased through good, Authorized Soundcraft dealer.  After a fairly long call with Tech Support, a brand new Impact was dispatched - with return shipping label for my B Stock one.
Hope you get things sorted out.  I agree, the M32 is more powerful, but it's also 74% more at MAP new-to-new.
Dave
Page created in 0.042 seconds with 21 queries.
