Pages: [1] 2 3 ... 6   Go Down
Author Topic: Gear Survey: What Amps Are You Using (Really)?  (Read 3143 times)
Rory Buszka
  • Gearmonger
« on: July 07, 2018, 08:47:05 pm »
Here's a fun idea: Gear Survey. The idea is simple - Post what you have, follow up with thoughts if you want to. The goal is participation.
I thought I'd start with power amps, since there are plenty of passive loudspeakers still in use, and they all need amplification. There's amps you can buy at Parts Express, Banjo Center, Musician's Friend, Sweetie-pie, and the like, and then there's amps you need to know a dealer in order to get -- for instance, I used to hear a lot about Camco (not as much anymore) and I don't think you can buy Powersoft at any of the above outlets, either.
The downside to this idea is that I really ought to go first. I'll betray my newb/"semi-non-pro" (bottom feeder, trunk slammer, hobbyist, local boob, call it what you want) status by saying I have a couple Behringer NU1000DSPs and an EPQ450. Well, at least it's something (in that it's slightly more than nothing). Reliability in the iNukes was questionable early on, but they haven't broken on me yet (for the few tiny gigs I have done with my "big toy stereo" - mostly favors, a couple outdoor parties and one girl-with-guitar, plus plenty of futzing around), and the iNuke DSP interface is dynamite, dead-simple for the basic configurations you'd want to do in processing, though it's not networkable and there aren't any 'frills'. As long as these hold on, these will probably be the last things I upgrade, though for subs I'm thinking of moving to a NU3000DSP for my two Community VBS112, and probably a second one for my RH TRX81/9 mains. (It's not called the Tiny PA for nothing.) Crest Pro-Lite is also on the menu...
Any takers?
« Last Edit: July 07, 2018, 08:51:13 pm by Rory Buszka »
Rory Buszka
The Tiny PA
Friends don't let friends mix a band from the stage.
The expert in anything was once a beginner.
Jeff Lelko
  • Cape Canaveral, FL
Re: Gear Survey: What Amps Are You Using (Really)?
« Reply #1 on: July 07, 2018, 09:00:10 pm »
QSC RMX for subs, QSC HPR tops.  10 years and counting have never missed a beat.
« Reply #2 on: July 07, 2018, 09:05:42 pm »
Any takers?
The Peavey IPR2/Crest Pro-Lite work well.  I use them in 8 ohm mode driving 1 driver per channel of our STX-828S subs.  I have 6 of them.
We still have 8 Behringer EP-4000 in mono-bridge each powering a B&C loaded 18" sub.
We have 12 Yamaha P3500S running bridge one per Meyer 650R2 dual 18 subs.
Crown Xti4002s on monitors
QSC - (4) PL340, (2) PL380 (4) PL236 running various subs and tops
The rest of our inventory is powered.
« Last Edit: July 08, 2018, 12:55:38 am by Scott Holtzman »
River Delta Audio is now:
Dave Pluke
    • BIGG GRIN Productions
« Reply #3 on: July 07, 2018, 09:30:59 pm »
Any takers?
Turbosound-branded, by MC2 (T15, T25, T45 for FOH) and Linea Research (Rack DP50 for primary monitor rack).  Plus, a few Crest Pro-Lites in a secondary monitor rack.
Dave
« Last Edit: July 07, 2018, 09:38:22 pm by Dave Pluke »
Martin Shifflett
  • Shenandoah Valley of Virginia
    • Sound Impression
« Reply #4 on: July 07, 2018, 09:33:56 pm »
Danley LAB subs: Peavey cs4080HZ
BFM DR300 array cabinets: QSC PL340 on mids, QSC cx404 on compression drivers
BFM Omni array cabinets: QSC cx404 on mids and compression drivers
12 wedges: QSC cx404 on mids and compression drivers
15 drummer sub: QSC PL340
All cabinets loaded with Eminence drivers.
Kemper Watson
« Reply #5 on: July 07, 2018, 09:40:38 pm »
Any takers?
QSC PL380's on subs
QSC PL 340 on tops
QSC PLX3602 on monitors
Jeff Bankston
« Reply #6 on: July 07, 2018, 10:09:51 pm »
QSC Series 3 from the 1980's.
Bob Leonard
  • Boston, MA USA
« Reply #7 on: July 07, 2018, 10:25:04 pm »
All QSC.
BOSTON STRONG........
Proud Vietnam Veteran
Stephen Kirby
« Reply #8 on: July 07, 2018, 10:38:16 pm »
Everything's active except the subs.  Those have a Crest Pro9200.  I carry a QSC PLX3204 and a BSS Minidrive DSP in a rack as a backup.
« Reply #9 on: July 07, 2018, 11:44:04 pm »
Crown I-Tech HD 12k, Crown XTI 6002, and we still have some Crown CE4000s running around.
Pages: [1] 2 3 ... 6   Go Up
Page created in 0.082 seconds with 21 queries.
