Pages: 1 [2] 3 4   Go Down
Author Topic: Y cord at DMX board  (Read 1563 times)
TJ (Tom) Cornish
  • St. Paul, MN
Re: Y cord at DMX board
« Reply #10 on: July 05, 2018, 07:25:13 am »
I don't see why a Y lead would be a problem.  The in and out sockets are parallel connected. Using a Y cable isn't any different.
Steve.
The reason DMX signal requires termination is due to the reflective nature of transmission lines.  Every time there is an impedance change (like going from the 120 ohm cable impedance to infinite ohms for an un-terminated cable end), the signal splits and while most of it still continues forward, some of it reflects back the other direction.  The more times this happens, the more the signal is degraded.  This has MUCH greater impact than simple cable distance, as itís not signal amplitude loss thatís the problem, but echo.
Fixtures in a line do indeed degrade the signal to some degree, which is why there is a fixture limit for a DMX branch, but itís not a big deal for the number of fixtures in spec if you use a terminator, which greatly reduces the impedance difference at the end of the line; thereby reducing the end reflection significantly.
If you put the DMX source in the middle of your chain using a Y-cable, now you have signal traveling in two directions, with two endpoints for the signal to reflect back from.  This gets noisy very quickly.  If both branches are terminated and the number of fixtures is modest it may indeed work, but itís going to be worse than if all fixtures are in a line in one branch in pretty much every case.
Optical DMX splitters are SO cheap.  The OP needs to get one and put it in an on-stage rack.  Mine lives in my digital stage box rack, and the DMX line is run with the audio snake (digital in my case).  Itís very convenient to split the signal from this point - upstage/downstage, left/right, etc.  Anything less than this is asking for trouble with a rig of 20+ fixtures.
« Last Edit: July 05, 2018, 07:27:15 am by TJ (Tom) Cornish »
John Fruits
« Reply #11 on: July 05, 2018, 07:31:45 am »
From Dr. DMX himself,
http://www.dfd.com/primer.html
Scroll down to DMX tips.
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs.  There's also a negative side."-Hunter S. Thompson
Steve M Smith
  • Isle of Wight - England
« Reply #12 on: July 05, 2018, 07:43:47 am »
So would a Y cable with a terminator on each branch be bad?
The only time I have used a Y connection was on a light with an intermittent connection on one of the connectors.  All this did though was duplicate the DMX out rather than send it out to two branches.
I'm amazed at what we have got away with though.  I have a 45 metre length of CAT 5 cable with an XLR at each end which we use for one event per year.  We have a wireless connection now though - so I don't ever need to coil that cable again!
Steve.
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #13 on: July 05, 2018, 09:01:32 am »
Do the DMX receiver chips have some ability to deal with reflected noise?  Yes.  Is it wrong?  Yes.  Is it better than two unterminated branches?  Yes.  Is the lighting for your show worth a $120 optical splitter to make sure it works?  Yes.
I don't understand your last sentence.  Only an active device like an optical splitter can "duplicate the DMX out".  Any other scenario does exactly "send it out to two branches".
Steve.
Cat 5 cable works very well for DMX and AES digital connections.  I'm not at all surprised it works at 45 meters/150 feet.  Many newer light fixtures actually have RJ45 ins and outs for exactly this purpose.
Steve M Smith
« Reply #14 on: July 05, 2018, 09:07:40 am »
I meant duplicate the physical connector rather than the output signal.
DMX out connector was intermittent so I ran into a Y adaptor with one branch going into the light and the other continuing to the next light.
Steve.
« Last Edit: July 05, 2018, 09:20:22 am by Steve M Smith »
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #15 on: July 05, 2018, 09:55:11 am »
Steve.
Thanks for the picture - that clarifies things.
In the grand scheme of crimes against humanity this is pretty minor, but technically you did create two branches - one of which is just one fixture long, but it's still an unterminated branch that causes signal reflections.  Once again it's less about the length of the run and more about the number of impedance changes that cause signal degradation.
Fun fact - the transmission lines course I took in college almost killed me, though I did pass the class.  Antennas are hard. High frequency is hard.
Dave Garoutte
  • San Rafael, CA
« Reply #16 on: July 05, 2018, 12:30:07 pm »
Steve.
Put the dead output fixture at the end of the chain.
Inventor.
duane massey
« Reply #17 on: July 05, 2018, 05:42:05 pm »
I have installed over 50 of these over the past 10 years with "zero" failures:
http://www.usledsupply.com/shop/dmx-splitter-1-8.html
Duane Massey
Houston, Texas
Steve M Smith
« Reply #18 on: July 06, 2018, 03:44:48 am »
Would have been a great idea if I knew which one it was before they were all wired and in place!
Steve.
Dave Garoutte
  • San Rafael, CA
« Reply #19 on: July 06, 2018, 12:16:27 pm »
Steve.
You could have skipped the bad fixture and then run a cable back from the end so it was last in the chain, even if it wasn't physically last in line.
Inventor.
Pages: 1 [2] 3 4   Go Up
Page created in 0.098 seconds with 21 queries.
