Pages: 1 [2] 3   Go Down
Author Topic: Different slant on IEM pullouts  (Read 1614 times)
River Delta Audio is now:
frank kayser
Re: Different slant on IEM pullouts
« Reply #11 on: June 25, 2018, 02:05:48 pm »
It's a knock off, not a real Senny.
Yeah. LOL! Either that, or the sales department at Sennheisers have gone off the rails!
Picture is labeled as xiaofega0.  Could be the retailer (not!)
A competitor to this phony is labeled on the transmitter and receiver as a FLZXJY.
Something fishy... Maybe a flounder. Probably working for SCALE. :P
If I can't pronounce it, I probably will not buy it.  No, that's not true, either...  I can't pronounce most acronyms. i.e., EAW, JBL
Jonathan Johnson
« Reply #12 on: June 25, 2018, 04:31:26 pm »
Eeeew! Gerbil!
« Reply #13 on: June 25, 2018, 05:30:07 pm »
"There was something fishy about the butler, probably a Pisces, playing for scale."  - The Fire Sign Theatre
I took their line and ran with it, taking a swipe at the 4 string LF guitarists:
"There's something fishy about the *bass* (like the fish) player, probably a Pisces, playing for scale."
Mike Caldwell
  • Covington, Ohio
« Reply #14 on: June 25, 2018, 06:04:15 pm »
I may be missing something here, you have four band members and only two IEM systems, are some members sharing a mix or are some of them on hardwired IEM packs.
You mention four mono channels after the two IEM's. Are you sending four mixes by using the stereo inputs on the IEM transmitters and then the band members use the focus mode on the belt pack to select between the two mixes on their channel to get the one they need.
frank kayser
« Reply #15 on: June 26, 2018, 10:52:44 am »
Mea culpa.  Worn memories.  Intellectual interlude.  Good swipe!
frank kayser
« Reply #16 on: July 11, 2018, 10:09:02 am »
Sorry I did not answer your question, Mike.
Correct I'm using FOCUS mode on the receivers to make four mono IEMS out of two transmitters.  Basically bought two IEM sets with two receivers each.
Dennis Wiggins
« Reply #17 on: July 11, 2018, 10:42:23 am »
...The first is the aforementioned Occlusion Effect, which is a MUCH bigger problem than you may think.
This may help others (like me) to understand the effect.  Is this like covering your ears with your hands and singing?
-Dennis
Occlusion Effect
« Last Edit: July 11, 2018, 10:53:14 am by Dennis Wiggins »
frank kayser
« Reply #18 on: July 11, 2018, 10:46:35 am »
[ url=https://starkeypro.com/pdfs/sas/A-Forgotten-Technique-For-Resolving-The-Occlusion-Effect.pdf ]Occlusion Effect[ /url ]
-Dennis
That's my understanding.  Now that you mention it, it would be helpful moving forward to make sure we're speaking the same language.  Anyone? Bueller? Bueller? Bueller?
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #19 on: July 11, 2018, 02:58:27 pm »
-Dennis
Occlusion Effect
It is.
Essentially, when you close off your ear, your ear canal becomes a resonant chamber. This chamber will make your voice sound more than just muffled, it will actually resonate at certain frequencies depending on bone conduction and other things.  And the larger the "chamber" is [in my experience], the worse the problem is.
This becomes a particularly sticky issue when mixing IEMs because the person is the only one that can hear it.  So they'll report to the ME that their voice sounds "muffled" or Boxy" or whatever, and the ME will think they're just being finicky since he/she can't hear it.
Now mix that resonance with a few milliseconds of latency and you've got all kinds of weird comb filtering and other stuff going on in your ear.  And it's different for every person.  Joy.
When i first started using and mixing my own IEMs i got to experience all of this first hand, and it's a very real and definite issue that has to be solved differently depending on the artist.  For me, running my IEMs a touch hotter and actually ADDING a couple ms of delay on my vocal mic helped a good bit.  But fixing it for some of my other singers required all sorts of different solutions.  And some never had an issue at all.
brian maddox
bdmaudio@gmail.com
Pages: 1 [2] 3   Go Up
Page created in 0.068 seconds with 22 queries.
