Pages: [1] 2 3  All   Go Down
Author Topic: Huh?  (Read 5353 times)
Andrew Broughton
    • Check Check One Two
Huh?
« on: March 22, 2018, 10:07:01 am »
Surprisingly poor labeling for a company that makes fantastic products.
Sent from my iPhone using Tapatalk Pro
-Andy
Dave Bednarski
Re: Huh?
« Reply #1 on: March 22, 2018, 10:54:32 am »
...almost looks like a knock off.
Andrew Broughton
Re: Huh?
« Reply #2 on: March 22, 2018, 07:50:32 pm »
I’m referring to the way of labeling the ground lift switch.
-Andy
Richard Turner
Re: Huh?
« Reply #3 on: March 22, 2018, 10:23:49 pm »
looks right compared to company website images
Looking at retiring. Local PA market has shrank to 2 guys with guitars and bose l1 compacts or expecting full line array and 16 movers on stage for $300... no middle left going back to event DJ stuff, half the work for twice the pay.
Andrew Broughton
Re: Huh?
« Reply #4 on: March 23, 2018, 02:02:26 am »
Sigh...
-Andy
Jay Barracato
  • Solomons, MD
Re: Huh?
« Reply #5 on: March 23, 2018, 06:52:03 am »
Sigh...
Looks to me like it might cause confusion between is the triangle a directional symbol that means the up position lifts the ground or is the triangle a ground symbol that means the down position lifts the ground.
Sent from my Moto Z (2) using Tapatalk
Jay Barracato
Keith Broughton
  • Toronto
Re: Huh?
« Reply #6 on: March 23, 2018, 07:10:10 am »
I read it as ground lift on output 2, up to lift.
However, it could have been made a little clearer if "out 2" was beside the switch and "ground" was at the lower end and "lift" was at the upper.
Jim McKeveny
Re: Huh?
« Reply #7 on: March 23, 2018, 07:36:13 am »
Agreed. Poor graphics. Disambiguation needed.
Also: The only control needed on the front/top panel is the stomp switch. Place Mic 2 Pin 1 Lift elsewhere. Like near Mic 2 connector. (See "Disambiguation").
Erik Jerde
Re: Huh?
« Reply #8 on: March 23, 2018, 08:37:57 am »
Pretty obvious to me but ymmv.  You’d only hit the lift to fix a problem anyways.  You hit it and it either makes things better, worse, or no change.  Doesn’t really matter what it had been when you flipped it.
Andrew Broughton
Re: Huh?
« Reply #9 on: March 23, 2018, 09:31:06 am »
The unnecessary arrow is pointing to the the connector, but it’s easy to think that it is indicating the direction to push the switch to enable the “lift”.
-Andy
Pages: [1] 2 3  All   Go Up
Page created in 0.084 seconds with 21 queries.
