Pages: 1 2 3 [4] 5 6 ... 14   Go Down
Author Topic: PSA: Sennheiser e904 $99  (Read 44462 times)
Dennis Wiggins
Re: PSA: Sennheiser e904 $99
« Reply #30 on: March 10, 2018, 10:29:11 AM »
904 for $99
Has anyone tried this mic with acoustic stringed instrument such as: mandolin, banjola (no drum head), or ukulele?
Oops -> Thanks Chris G. You already answered that!
-Dennis
« Last Edit: March 10, 2018, 10:37:54 AM by Dennis Wiggins »
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #31 on: March 10, 2018, 12:22:31 PM »
No worries. I'll talk to the musician and see if it'd be okay to post a quick recording.
Chris
www.grimshawaudio.com
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #32 on: March 13, 2018, 06:03:46 AM »
Alrighty, here we go.
Really quick demo recording of a ukulele in a pub in Sheffield. e904 was around 3-4" out from where the neck meets the body, a little above the instrument pointing 45-degrees downwards so it was pointing at the middle strings. Desk was a QSC TM16, analogue gain all the way up. Apart from normalising the track so it hits 0dBFS and converting to MP3, there's no processing at all. Not even a highpass filter.
https://soundcloud.com/grimshawaudio/e904-uke
Plenty to work with there IMO, and with the monitors firing at the side of the microphone there was still enough GBF to hear the monitors over the instrument. I expect that with the mic angled so it was pointing directly away from the monitors, there'd be even more GBF on offer.
I went back through and also found this:
https://soundcloud.com/grimshawaudio/e904-agtr
Acoustic guitar (obviously), can't remember the mic positioning though - probably around 6" away for a guy standing up with it and having a bit of space to move. There was quite a bit of monitor spill when he started singing, but the vocals were pretty loud and it wasn't exactly close-micing.
Chris
jim whitmer
« Reply #33 on: March 13, 2018, 11:57:59 AM »
Thanks for the heads up!!!
Aaaaaaaaaaaaaaaaaaaaaaand $200 gone : ' )
Dave Garoutte
  • San Rafael, CA
« Reply #34 on: March 13, 2018, 03:17:38 PM »
No no no! You SAVED $200. (Me too).
« Last Edit: March 13, 2018, 07:05:43 PM by Dave Garoutte »
Callan Browne
  • Melbourne, Australia
    • Rubix
« Reply #35 on: March 13, 2018, 10:48:42 PM »
Thanks Mike! 2 incoming here.
I'm hoping the e914 has a big sale at some point this year too, I could use a pair of them.
Sent from my Pixel using Tapatalk
Melbourne Cover band: Rubix!
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #36 on: March 18, 2018, 06:16:56 AM »
Just a quick note (I'm on my phone) to say the gig last night went pretty well. Since I now have eight of these mics, I put them on pretty much everything. Not had chance to go over the recordings just yet, but here's where I put them:
Guitar cab
Bass cab (not expecting good results - it was a 1x15" combo with a crapload of low and high boost, cranked up so loud I didn't put it in the PA)
Snare top
Snare bottom
Rack & floor toms
Second kick (same positioning as main kick mic, just outside the port - I wanted to see how it'd do for a main kick mic)
Hi-hat
Overhead
The astute observer will note there's nine things listed. I moved the hat mic to kick after the first set.
It was a small venue, so I didn't need the snare, hat or overhead mics anyway, but I did push the toms up a bit and they sounded fine without any messing around. Guitar cab sounded fine, too. I'll see about posting a couple of clips of each channel.
Its worked out rather difficult to get photos from my phone to your screens, so that'll have to wait until I'm on my laptop.
Chris
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #37 on: March 18, 2018, 03:26:15 PM »
So, I've had a listen through the recordings. It's a small stage so the cymbals got into most things, and the drummer's monitor got into the rest.
Mic positioning was all pretty standard. Clipped on to the drums, aimed roughly 2/3rds of the way to the centre. On the cabs, somewhere around half-way between the dustcap and the edge of the cone. Pictures at the bottom. I wanted the guitar amp's mic closer to the centre of the cone, but was limited by mic stand dimensions and stage space. The latter was at a particular premium, with a 6-piece band on a stage around 12' square.
Some tasting notes as I go through the recording...
- There's some missing low-frequency extension with the e904 compared to the kick mic I usually use (sE Electronics X1D, a large-diaphragm condenser). Running both through a spectrum analyser on Audacity shows the X1D has content at 32Hz as strong as 140Hz, and 16Hz is around 3dB down on both.
The e904 has 32Hz 15dB down on 140Hz, and 16Hz around 8dB down on 32Hz, or 23dB down on 140Hz.
That said, it's not necessarily a bad thing. I could take or leave either kick sound. The X1D sounds more "deep" while the e904 is more "punchy". Both would work live just fine, in my opinion, though the X1D means you've got the low-frequency information there if you want it.
So, it'd work in a pinch, but probably wouldn't be my go-to kick mic unless I needed something with a really small form factor. You can bring out some more of the high-end "click" by boosting in the kHz range, and I expect the e904 would work well as an inside kick mic, too.
- Toms sound great as they are. Clip them on, highpass filter if you're willing to expend the effort, push the fader, done. Nice balance of attack and body. Bleed from the rest of the kit sounds exceptionally natural, too - I had to double check to see if I'd left any other channels playing while cueing the toms. There's around 18dB level difference from the rest of the kit to when the toms are hit, so there's not a lot of bleed. It's just what bleed there is sounds good.
Floor tom has enough bottom end, though it wasn't massive - fundamental was just below 90Hz.
- Snare's also great. Same story as the toms. Snare top, snare bottom, invert bottom, push faders. Done. Immediately sounds like the snare itself. You can leave both mics with the same polarity, but you lose the bottom fundamental of the snare, giving a sound that's thinner, but could be considered more "snappy". I wouldn't complain at either sound, but I prefer the fullness of the sound you get from running the bottom inverted.
- Hi-hat works fine. The mic was positioned at the opposite side to where it's being hit, so there's not much stick attack, but the metallic bits sound good - no obvious lack of high-frequency extension.
- The bass cab sounds as good as can be expected with the amp's EQ settings in place. I'm going to reserve judgement on that until I've had chance to use it on an amp that's set up nicely.
- Guitar cab sounds fine. Could be sculpted if you wanted more "edge" on the distortion or whatever, but sounds like the guitar amp from the off. Bit of bleed from the cymbals that happened to be 3' away.
- For me, the absolute standout is using an e904 as an overhead. It works really well - you get a really good overview of the drum kit (with plenty of the drummer's monitor, of course, as he had earplugs in and wanted it turned up). Blend in the kick and you've got a natural-sounding perfectly-mixed kit sound. I'm genuinely amazed at how well this little mic picks everything up. Take the drum parts of Springsteen's Jersey Girl, for example. It's all there. All the bits on the toms, ride cymbal, rim shots on the snare, etc etc. I really hope someone tries this to confirm I'm not going crazy here.
Some pictures:
Cheers, all.
Chris
David Morison
  • Aberdeen, Scotland
« Reply #38 on: March 20, 2018, 11:50:57 AM »
Not only that, but from your photo in next post he had the "shape" function enabled too, which adds about another 10dB of contour on top of the graphic!
FWIW,
David
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #39 on: March 21, 2018, 05:01:16 AM »
FWIW,
David
Both "shapes" were enabled. Didn't realise it was that much boost, though. Ouch.
Kinda feeling sorry for the poor bass amp, now. I did notice there was a blinky red light lit up whenever he was playing. Reviewing the pictures, that's "Overload".
I've got mostly acoustic-type stuff for a while now, but will update somewhere if I get to try it with another bass amp.
Chris
Pages: 1 2 3 [4] 5 6 ... 14   Go Up
