Author Topic: USB data over wireless UPDATE  (Read 1586 times)
Keith Broughton
  • Toronto
« on: February 26, 2018, 02:21:26 pm »
I would like to be able to control USB devices, like an amp DSP or DSP speaker processors, wirelessly.
Basically, replace a USB cable with a wireless connection that would not require a computer at  the amp or processor side of the link and allow a laptop connected to a WAP to control.
Is this possible with a USB to LAN adapter and some kind of WAP?
Any suggestions or ideas?
« Last Edit: March 10, 2018, 06:51:44 am by Keith Broughton »
Scott Helmke
Re: USB data over wireless
« Reply #1 on: February 26, 2018, 02:32:32 pm »
Andrew Broughton
    • Check Check One Two
« Reply #2 on: February 26, 2018, 05:55:31 pm »
Windows? Is the WAP by the device being controlled?
If so, there are lots of choices.
Here's one:
https://www.startech.com/Networking-IO/USB-PS2/10-100-1000-Mbps-Gigabit-1-Port-USB-over-IP-Device-Server~USB1000IP
-Andy
Keith Broughton
  • Toronto
« Reply #3 on: February 26, 2018, 07:44:25 pm »
Here's one:
Let's see if I have this right...
I can use this USB PS2 device to connect to the USB port of the device under control (say a QSC amp with DSP) and that will connect to a WAP (locally) via CAT cable.
I can then connect my laptop to the WAP via WiFi and control the amp with the QSC software.
Scott Helmke
« Reply #4 on: February 26, 2018, 08:57:16 pm »
Exactly. The USB server comes with software to mount the USB ports (over whatever network you have) as if they were local to the computer.  I had that same box a few years ago when I needed to do USB remote control of a speaker DSP.
Keith Broughton
  • Toronto
« Reply #5 on: February 27, 2018, 05:41:41 am »
I imagine if I wanted more than 1 device under control, a regular USB hub would not work and I would need the 4 port device in your first response.
Thanks Scott :)
« Last Edit: February 27, 2018, 05:49:51 am by Keith Broughton »
Andrien (No Last Name)
« Reply #6 on: February 27, 2018, 07:19:09 am »
Thanks Scott :)
You can use hub, but most will run at 1.1 spec and not 2.0 on hub mode. You are also limited by the fast ethernet bandwitdh but for configuration I think 1.1 will do. Most also doesn't support more than 7 devices due to 1.1 limitation on hub mode. Cmiiw though
Chris Eddison
« Reply #7 on: February 28, 2018, 04:05:15 am »
Iím using a Belkin network usb hub for this purpose - albeit remote monitoring Trantec radio mics instead.
A more flexible solution would be virtualhere. This is a range of solutions, some of which involve buying inexpensive network devices such as a TPLink travel access point, and then flashing them with their custom firmware to make them in to a usb over IP converter. The one Iíve bought has the added benefit of either offering you an RJ45 to connect to your network (what I do) or (as itís an access pointvalready), just connecting to it directly by WiFi.
A good product and I believe for a single device itís free too.
Keith Broughton
  • Toronto
« Reply #8 on: February 28, 2018, 09:47:13 am »
Here's one:
I purchased this product and was able to get the results I want.
t\Thanks :D
Keith Broughton
  • Toronto
« Reply #9 on: March 10, 2018, 06:50:21 am »
I have had a chance to use this on a number of different USB controlled devices and it works great😄
Thanks
Page created in 0.065 seconds with 21 queries.
