Author Topic: DSP amplifier limiter calculation  (Read 6710 times)
Roberto Orozco
Re: DSP amplifier limiter calculation
« Reply #10 on: February 24, 2018, 11:03:09 AM »
The BEST way to set limiter voltages is to MEASURE them, using a sine wave a voltmeter.
Calculators can be useful-IF everything is correct that is entered into them.
I have know some amp gains to be different (as much as 4dB) than what the spec sheet says.
I know one major amp manufacturer who considers the gain to be normal if it is +/- 1 dB over published specs.
Simply put a sine wave in, adjust the gain so that the measured voltage on the output is higher (I like at least 10%) than the voltage you will limit to.
BE SURE the speakers are NOT hooked up at this time!!!!!!!
Then simply turn down the threshold until you get to the desired voltage.
If you are using multistage limiters, be SURE to do the peak or highest limiter first, and the continuous or heating limiter last.
Hi Ivan, I appreciate the information. like I mention before, my knowledge on the field limited (ha ha, talking about limiters! sorry)
I'm always willing to learn!  is there any video tutorial or link that could show me how to do that the you mention with my amplifier?
probably takes more than a video to understand and do it the proper way! maybe I need equipment that I don't have in my basement right now I can tell you that, I do have a voltmeter!   I just would like to finis my project with the best possible results.
thank you so much for the advise.
« Reply #11 on: February 24, 2018, 05:54:13 PM »
All you need is a voltmeter and a signal generator.
There are free apps, or you can download various sine waves.
Just follow these steps
LIMITER VOLTAGE-How to measure preset settings.
When determining what voltage limiters are set at, without a voltage number, you must measure the actual voltage output of the amplifier.
It is VERY IMPORTANT to use a voltmeter that has a flat response in the audio freq range.  MANY do not.
If you are using a meter that does not have a flat response, then you should ONLY use a test freq of around 60Hz.  This may mean bypassing various HP filters during the test, but be SURE to turn them back on after the test.
If you are using a flat response volt meter, then use a test freq around the middle of the response range of interest.  It does not have to be exact, just somewhere in the range before rolloffs
1: DISCONNECT the loudspeakers!!!!!!!!! And hook the voltmeter to the output of the amplifier in question.
2: We are going to “assume” a 2 stage limiter.  If there are more (3 is ideal), then simply add the additional steps, which are the same basic procedure.
3: Apply a sine wave to the input of the device/system and turn the level up until the voltmeter does not increase with increasing signal level.  MAKE SURE that no stages prior to the amplifier or the amplifier itself are clipping.  If they are, then readjust the gain structure of the system.
This voltage should be the or “heating”, or “RMS” limit of the system.  Note the voltage and write down the threshold setting.
4: Now either bypass the limiter in step 3, or raise the threshold to the maximum.  Now increase the drive level until the meter no longer increases in voltage. MAKE SURE there is no clipping anywhere in the system path-including the amplifier.  Readjust gain structure if needed.
This voltage should be the peak voltage.  Note this voltage
5: Re-engage the limiter in step 4 that was bypassed.
6: If there is a 3rd limiter, it would be the program limiter, and the step for it would be between 3 and 4 above.
7: Reconnect loudspeakers
ROUGH GUIDELINES FOR LIMITER SETTINGS
Voltage.  Determine the continuous voltage rating.  The formula is the square root of (continuous power rating x impedance).
Use this as a basis, the thermal or RMS limiter should be ½ of this voltage (1/4 power).
Program limiter should be the continuous voltage rating
The peak voltage should be 1.414x the continuous voltage (2x power).  YES, that is 3dB down from the actual peak rating of the loudspeaker, but it has been determined that this is a safer setting to use than the “near death” rating.
ATTACK TIMES
Thermal/RMS   large subs 3seconds, general woofers 1 second, midrange 0.5 seconds, HF 0.1seconds
     Release time should be 1.5 to 2x attack time.
Program    The attack time should be equal to the freq of the high pass filter for the xover.  Ms=1130/HP filter freq.    The release time should be between 10-20x attack time-15-16x is considered “ideal”.
Peak should be as fast as possible.
Roberto Orozco
« Reply #12 on: April 05, 2018, 09:59:28 AM »
ATTACK TIMES
hi Ivan, first of all I want to say than you for your help and advise.
I tried to do what you told me, I'm not sure if I did the right way but, this is the result:
I connected the voltmeter low frequency  out put of the amplifier, I used I sine wave app at 120Hz, the readings on the voltmeter were 0.00 at this time. I started to turn the volume up but the voltmeter never stop moving until I reached the max volume on the amp, the numbers I get were 30.7  I was measuring AC volts.
after I reached the max volume the voltmeter stop.
the frequency cuts from the manufacturer for this speaker are 700Hz, 3000Hz, so for the 6" driver I used a sine wave at 1200Hz  and for the high frequency driver I used a 5000Hz sine wave. after repeating the process on each driver this are the numbers I get:
L-30.7
M-15.3
H-10.5
I did the test second time  using a really cheap voltmeter that I found in my garage but the readings were even smaller:
L-12.8
M-8.3
H-6.7
I'm not sure how good the battery was on this one but the number moved a lot.
my amplifier only have one box for each output  to setup the limiter, I thing that's what is called I stage limiter...not sure.
-the threshold only shows numbers from -1dB to -7dB
-the attack only shows number from 0.5ms to 50ms
the release from 100ms to 500ms
and the ratio:
I want to use the amplifier to drive 2 X 12'' woofers 550W RMS each 8ohms
2 X 6" drivers 100W RMS 8ohms
and
2 X 1.75 HF drivers 100W RMS 8ohms
not sure if that's actually possible!
I'll be using this cabinet as tops for my system, with a powered 18" subwoofer. the subwoofer has a HP filter at 120Hz (optional)
most of the time we will be using just 1 cabinet  per side with the 18" sub since we played at small venues or backyards.
I hope this information can help and if you don't mind give a most accurate number for my limiters so I can protect my speakers, thank you.
Best regards:
Roberto Orozco.
« Last Edit: April 05, 2018, 05:08:48 PM by Mac Kerr »
Ray Aberle
    • Kelcema Audio
« Reply #13 on: April 05, 2018, 04:56:39 PM »
Move the [/quote] tag to just BEFORE your response, and it'll keep your reply out of the quoted text. :)
Kelcema Audio
Page created in 0.029 seconds with 21 queries.
