Located in Eastern Canada, so likely only of interest to folks in Canada or someone really wanting this stuff. Willing to ship on your dime. can accept credit card on small items NO PAYPAL. long list but its just easier to copy past the full local sell sheet.
PLEASE email directly to
[email protected] with real questions or offers. all gear is used and in good to excellent condition. if your a freak who expects a 20 year old rack box to have zero scuffs or bites on the rack ears please look elsewhere....
PASSIVE LOUDSPEAKERS
yorkville system, selling complete or make an offer that motivates to break apart
4 yorkville ef508
4 yorkville ls808
2 ap4040 amps ef508 processor (have extra processors to make 2 small rigs)
cable package nl4 terminated 14/4 speaker wire 1-75' , 1-30', 6-6' amp rack suitcase
2 yorkville SW1000
2 dual 15" boxes made to jbl plans, have 4 jbl drivers that would work well in them.
Yorkville elite e10, 4 available
POWER AMPLIFIERS WORKING
1 crest ca4
2 crest ca6
7 Crest CA9
3 Yamaha P7000S (avail as lot of 3 only)
Yorkville ap3000, just back from Yorkville, repaired and working as new
Yorkville AP2020, just back from Yorkville, repaired and working as new
Yorkville AP6040, just back from Yorkville, repaired and working as new
SNAKES
32x8 150' with 25' monitor split, older in case on wheels
16x4 rapco 100’
30 channel doghouse snake 20' approx
50' 8 channel cross stage snake, was used to connect amp racks fan tail both ends Mogami cable 6 send 2 return
65' BRTB 24x0 snake, could be put back to 16x8 or 20x4 etc
insert snakes several 4 channel several 6 channel boston green cable beutrik ends
insert snake, 1/4" trs to XLRM/XLRF BRTB 6ft.
CABLING
used 14/2 stage speaker cable used 12/2 stage speaker cable 25, 35,50ft lengths
will have to measure cable inventory most is NL2 or NL4 terminated
CONSOLES
Allen Heath Mixwizard wz3-16 2 available
Crest Century GT 32 channel 4 band swept on all channel 8 bus in compact travel case
Allen-Heath GL2800-24
Allen Heath QU16
RACK GEAR
Yamaha SPX90 checked over by yamaha auth tech, reset to factory new battery good piece
Yamaha SPX900 checked over by yamaha auth tech good piece
BBE sonic Maximizer (2 available)
3 Valley Dynamite dual comps
2 yorkville ef508p processor 1 listed with speaker system, 3 total.
TDM 24-CX2 crossover
3 Yamaha Q2031 EQ 2 are good, 1 needs 4 faders
2 yamaha gc2020 dual comps
2 Q1031 yamaha eq
ashley GQX 3102 eq
DBX drive rack PA 2 available
2 BEHRINGER fbq3102 EQ
2 Yamaha Rev 100
Behringer quad comp
Behringer quad gate
2 Peavey EQ Q431fx
2 Peavey EQ eq31fx
Peavey EQ Q231fx
2 Peavey Q215f
2 Yamaha F1030 frequency dividers nice vintage pieces
DBX 1074 quad comp
DBX 1076 quad gate
5 behringer intelligate xr2000, 2 are new in box, one of the few things they did right
3 DBX 1066 Gate/comp
3 DBX ieq31
Cases and Racks
11 space rack ATA no wheels 16" center
13 space ATA 16" center wheels
9 space plywood rack 16" center
4 space fur covered rack box
3 space levys nylon zipper bag case bass head use etc
2 22x28x8 ATA case, was horn box
24x24x24 j rack case on casters rack missing
4 bose802II travel covers
9 space rack 16" center
2 3 space ATA suitcase 16" center
20x20x30 trunk on casters
22x22x7 mixer case
Roll around mixer rack 12 space below, fits mixwizard or similar compact
Roll around mixer rack 14 space below deep center, will fit presonus mixlive or mackie onyx,
set of nylon zipper bags for yorkille lights and controller
Gator GRC 10x6 mixer case, will fit mackie vlz or mixwizard
Gator GRC 10x2 mixer case.
Gator 18x42 case set up for mics and cables. 12 space mic holder and dividers etc
Raw Drivers Working
RCF woofer for original Mackie SRM450
4 yamaha JA3881 woofers white cone retail model NOS
2 Yamaha 4281b HF tweeter, blown but come with NOS diaphragms
4 JBL 2424H Babycheeks tweeter
2 JBL 2225H
5 JBL 2446J 2" exit
4 Yamaha JA6681B compression driver, plus 2 or 4 NOS diaphragm
4 jbl 2220j? would have to recheck
Raw Drivers For Recone
4 DAS G45 1 works 3 burned were in cabs listed above 8 peavey 22xt magnets
2 JBL d140f alnico
1 JBL 2142H
12 yamaha JA4201 compression driver some working
2 Celestion G18Q-400 18"
4 eminence Magnum18LF
Eminence omega pro
Ground Support
2 36" aluminum bars with bolts for 4 cans
2 single stage manfrotto, with 4' extention pipe and 4' tee bar.
2 Yorkville SKS21B stands with Tee bars
LIGHTING CONTROLLERS
Elation Scene setter 8
Elation Stage Desk 16
Sunn SC24f 4 channel 2 scene MPX protocol
behringer light desk?
NSI DLC2400 CHASE CONTROLLER mpx dmx OUTPUT
SFC-288 8 channel dj lighting controller
Pulsar rainbow strobe
ADJ 24 channel touch controller
martin 2532 controller pad
NSI MC7016 has DMX and MPX output
ADJ MYDMX dongle version 1 2 available
Yprkville LPC-12
Yorkville LPC-4
Lighting Dimmers relays
Chauvet CH-865 chaser, new in box
2 elation DP-415 dimmer
2 Elation DP-640b
4 4 channel pinspot chasers
NSI NR4600 relay 4 channel 600w
4 NSI ND4600 dimmer 4 channel 600w
NSI DDS 6000 4 channel 1.2kw
Lighting LED
6x Chauvet Colorsplash 196 plus colorboss controller
Yorkville LP-LED4 4 available
Lighting cans
32 pinspots par 36 most no bulb
Lighting Intelligent
4 Trackspot
8 Martin Roboscan 812
12 Martin Roboscan 518
8 Martin Robocolor 400 these are stand alone units 4 no bulb
2 Angel RG 50 lasers dmx,
2 Chauvet DJ Squeeze
2 ADJ Revo Sweep
2 martin mac500, need minor parts, drive belt, would recommend rebulb,
1 martin center piece, ran when pulled is all I know on it. mirror barrel wrecked but I think I have the metal plated and a few pieces of glass for pattern.
9 ADJ pocket scans with controller AS IS for parts or repair only, 2 were functional when pulled
DJ plug and play lighting
Martin Discovery
Martin Voyager
ADJ Warp
LIGHTING OLD SCHOOL
2 coemar eyebrow lights aluminum case DYS bulb
pinspot rack system from 1985, was functioning in club untill last year, control system had 10 bars of 10 pinspots each, approc 60-70 working bulbs color organ plus another relay pack to controll other lights
portable pinspot system 8 bars of 8 pinspots each, control system, cables, worked well as blinder system. Controll box orig had nsi relay pack inside it
SPEAKER PARTS
pair of HDH top boxes fibreglass mid horn, takes 12" woofer plus this
Boxes of speaker handles and hardware couple dozen steel handles. plastic cup with alum bar handles, grille clips, corners pole cups etc.
