Author Topic: Something interesting just happened to me...  (Read 1786 times)
Casey Sharp
« on: February 06, 2018, 04:33:02 pm »
Something interesting just happened to me about 10 minutes ago.
I am frequently having to bounce between 120V and 240V. So what I did was install 2 power conditioners in the same rack and just use whichever one I need.  I was testing my 240V conditioner with a step-up transformer just to make sure everything was working properly. Afterwards I powered down and unplugged the 240V conditioner and back into the 120V. I plugged the 120V conditioner into a 120V wall outlet. Once I flipped the power on I heard a pop inside the conditioner and assumed it was an internal fuse. So I just took it apart and sure enough I popped a disc fuse, but my outlets are still working.
Any idea why this could have happened?  My only thought is that I had just ran some gear on 240V and when I plugged that same gear back into the 120V conditioner maybe some capacitors sent some stored energy backwards through the conditioner and thats what popped it.  But I don't know.
Ron Hebbard
Re: Something interesting just happened to me...
« Reply #1 on: February 06, 2018, 05:02:46 pm »
Any idea why this could have happened?  My only thought is that I had just ran some gear on 240V and when I plugged that same gear back into the 120V conditioner maybe some capacitors sent some stored energy backwards through the conditioner and that's what popped it.  But I don't know.
  Casey?  You "popped a disc fuse"?  Or you popped an MOV?
Toodleoo!
Ron Hebbard.
Mike Sokol
« Reply #2 on: February 06, 2018, 05:56:19 pm »
That's not possible. Got to be something else...
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
« Reply #3 on: February 07, 2018, 02:41:48 am »
What is your concept of "conditioned" power?
If you're using surge protectors I'd say your recent event shows they work but they don't do any "conditioning"... hell, they probably don't do a power shampoo, either. ;)
Keith Broughton
  • Toronto
« Reply #4 on: February 07, 2018, 05:57:21 am »
An amusing start to my day Tim  ;D ;D
Chris Hindle
« Reply #5 on: February 07, 2018, 01:10:01 pm »
As Ron said, you popped an MOV, not a fuse. It is supposed to take the "bad shit" and pass it to the Neutral (or ground, i forgot) so it bypasses your gear. This is why the gear still worked. They wear out. When going bad, they will also add noise to your system, and trip GFCI breakers.
Personally, i have UPS in the system, and power bars. No damn "conditioners"
Chris.
You can turn a "conditioner" into a power bar by clipping out the MOV.
Page created in 0.08 seconds with 24 queries.
