Could 1 channel from a I tech controll 1 WS218x? Or do I need 2?
A second hand Itech is about the same price as a new XTI6000 (here in The Netherlands)
If you are just getting a single amplifier then certainly, a single channel at 4 ohms nominal can drive a WS218X well.
For longer cable lengths (you mentioned 10 meters) the amp can provide better control of the driver with an 8 ohm rather than a 4 ohm load and it will also have less power loss in the cable. That is why I was recommending a single amp channel per driver (that is also why Martin Audio wired the WS218X in a way that allowed 2 pair of the NL8 cable to drive each speaker driver). For your setup I think the difference between 4 ohm and 8 ohm would be minimal.
The bigger factor would be having some built in redundancy. You could always drive both subs of one amp in a pinch.
Would having 2 sub amps give you enough amps to have 2 amp racks, one for each side of the stage?
This would let you have 2 short cable runs instead of one long and one short.
That would improve the amplifier control and reduce loss through the cables. It also could be setup to make everything redundant.
Mostly just thinking out loud here. You know what your needs are for return on investment, size of your show pack, etc.
Lee
