Author Topic: Can not find what the problem may be please help  (Read 5809 times)
  • Old enough to know better
  • Audio Plumber
Re: Can not find what the problem may be please help
« Reply #10 on: January 17, 2018, 09:18:33 PM »
Is it possible there is a compressor in the signal chain? When you say yelling into it causes it to come back on a "duck" comes to mind.
Or a bad solder joint.
Steve Alves
  • South Florida
    • South Florida Sound
« Reply #11 on: January 17, 2018, 09:27:41 PM »
Yeah, but a compressor is easier to check for. I hate when I spend a bunch of time on a problem and it was something simple and obvious I missed.
Steven Alves
South Florida Sound, Fort Lauderdale, FL
www.southfloridasound.com
Casey Sharp
« Reply #12 on: January 18, 2018, 05:10:35 PM »
It is certainly hard to find a problem if you are unable to recreate it.  It may sound obvious, but start with that. Think back to the times it happened... does anything stick out to you that may have caused it?  If not, play some music and start jiggling inputs and outputs between the console and the amps - it could very well be a bad cable.
Is the system stereo or mono? Do you have delay speakers or front or side fills?  Do you have a video feed and if so did you lose audio to there or to any of the other speakers?  If the answer is yes to any of these then find where those feeds are tapped in and you know it's somewhere between there and the console.
Another thing... Is it a possibility that you just straight up lost power to your amps or DSP?  Was there a pop of any sort when it all came back on?
Eric Babington
« Reply #13 on: January 22, 2018, 04:54:39 PM »
You guys/girls are awesome. Thanks for all the advice and tricks and pathways to run down. It was the Ultradrive. I replaced it with a DBX PA2 and all is well once again. Thanks for all the help!
Don T. Williams
    • Q Systems Music & Sound
« Reply #14 on: January 22, 2018, 06:35:26 PM »
Just as I suspected!
Page created in 0.02 seconds with 21 queries.
