Author Topic: Removing speaker grille foam  (Read 583 times)
Helge A Bentsen
  • Oslo, Norway.
« on: January 07, 2018, 05:43:08 pm »
Will removing foam from the inside of speaker grills affect sound quality?
Case in point, I'm refurbishing 8 KF750 and kinda like the look of them without grills, but I need the grill to support the horn, so I was thinking about using them without foam on the inside.
I haven't tried this yet, the grills need a paint job first which I'm hoping to start on next week.
Dave Pluke
    • BIGG GRIN Productions
Re: Removing speaker grille foam
« Reply #1 on: January 07, 2018, 07:54:31 pm »
*Might* impact the dispersion of the higher frequencies.
Dave
« Reply #2 on: January 07, 2018, 09:16:48 pm »
I would suspect the grill itself would make a bigger difference than the foam.
Of course depending on the thickness and density of the foam.
All loudspeakers sound better without the grill-due to the blockage and backwards reflections that grills offer.
But then you have the protection of the drivers from the elements.
There are a number of tradeoffs regarding grills.
Craig Hauber
« Reply #3 on: January 08, 2018, 09:59:23 pm »
I find a lot of grills rattle when the foam is removed.  You will need a roll of foam weatherstripping to gasket everywhere that metal touches.  Then tap gently all around on it with a rubber mallet to find the rattles and add more foam if necessary.
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Page created in 0.024 seconds with 18 queries.
