Author Topic: LED panel suggestions  (Read 627 times)
eric lenasbunt
    • Bunt Backline Event Services, LLC
« on: January 03, 2018, 12:32:02 am »
If you needed 2 ~16íx9í led walls, 4mm-6mm pitch and ip rated, what would you be looking at? I currently have Chauvet PVPX6ip panels but may be losing them to a tour soon. Thoughts? We are a regional production company.
James Feenstra
Re: LED panel suggestions
« Reply #1 on: January 03, 2018, 04:45:53 pm »
Absen most likely, if I was going from not having a product to making an initial purchase
If I already was invested in one product, I'd probably expand on my inventory of that particular product as I needed more inventory.
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
« Reply #2 on: January 03, 2018, 04:48:48 pm »
Disclaimer, I know nothing about LED Walls, just that I like them and I have direct access to a very old one.
Wouldn't you want the same make/model so if you need to use both at same time you get same color/brightness/contrast?
eric lenasbunt
« Reply #3 on: January 03, 2018, 09:52:13 pm »
Thanks for the replies guys. Chauvet will still make the panels I have, but they are effectively discontinued. If this tour deal goes through I would have fully depreciated and would be ready to sell my current panels regardless. Thatís why Iím looking to go a fresh direction. Panel tech has improved as well, so if buying new I want to get latest tech
James Feenstra
« Reply #4 on: January 04, 2018, 04:23:02 pm »
in that case, look into the absen Xv series, and see if you can get them with the brompton processing over the novastar, as theyíre better processors over all
http://www.usabsen.com/mobile-xv-series/
www.elevationav.com
Page created in 0.021 seconds with 15 queries.
