Just a couple of thoughts for now:
First, my biggest concern is low-mids throw, so critical for rock music. I'm really surprised to see so many recommendations for the Danley SM80.
Great boxes, but I've heard these at two different event, & I don't think they are any good for rock, past about 30-50 feet. Mind you, Danley makes great stuff, but these are an odd duck. Just a single 12" coaxial in a sealed cabinet. OK, there's a bit of waveguide extension, but it's still 90º conical, so you're also losing energy vertically, and potentially getting some phase smear when indoors.
One idea I have right now actually does involve a Danley product, but it's an unusual idea: I'm thinking of using a pair of SH95HO's, combined with a custom-made pair of dual 10's for 100 - 400Hz.
And perfect dispersion control down to 400 Hz.
I only wish the SH95HO had a 2" exit, but you can't have everything.
I'd love to hear your thoughts on this idea.
As Mac said, you MUST use your full real name on these forums, or the thread will be locked or your posts deleted
Pattern control is something that is VERY VERY misunderstood.
Most people DO NOT understand what it means, even though they think they do.
Often people ask for a narrow vertical pattern. HOWEVER that means that it MUST be much larger, to have the same degree of control.
Given 2 horns of the same size, the one with the larger pattern will control lower.
So a small vertical size and narrow vertical pattern means that you will ONLY get that vertical control over the top couple of octaves, NOT down lower.
As you go lower, the pattern will get wider and wider, which means that at the lower/mid freq, it is actually WIDER than a "wider" rated horn.
You may find it very difficult to get a pair of 10" front loaded drivers to keep up with the SM80. And then you have to consider the interaction of the different boxes. The fewer boxes you use, the easier it is to get them to line up.
Consider also that the SM80 has a very high impedance below 150Hz. SO you can actually boost those freq a good bit. Because the impedance is high, the driver will not be dissipating a lot of power, and because it is a sealed box the excursion will be under control.
Or you could run the subs up a little higher to get more punch out of them.
Why would you want the SH95HO to have a 2" exit. It has a 1.4" exit
The wider the exit on a HF driver, the narrower the pattern will be at the higher freq (due to the size of the exit of the driver in relation to the freq at the throat of the horn.
2" drivers are not the "bees knees" that many people think they are. Historically they have gone lower in freq, and are louder in the 2-4Khz range, but actually they are quieter in the upper freq, where it is harder to get output.
So 1" drivers typically have greater output in the top octaves than 2" drivers.
Unless you MUST go lower, I would avoid 2" drivers.
Everything is a trade off. It is important to understand the tradeoffs when making decisions.
