Author Topic: Spacing of Paddle Antennas?  (Read 2768 times)
Scott Hofmann
« on: December 29, 2017, 02:43:19 PM »
What would be the ideal spacing between two paddle-type receive antennas for 500 mH wireless mic band?
Will be mounted on the facade of control booth facing the stage.
Scott Hofmann
Lyle Williams
Re: Spacing of Paddle Antennas?
« Reply #1 on: December 29, 2017, 07:11:25 PM »
I'm assuming that this is two paddles feeding the one diversity receiver.
There is no ideal separation.  I'd go for at least a foot apart.  Wider if mounting allows.
More important is to deal with polarisation.  Tip one antenna 45deg left and the other 45deg right.
Henry Cohen
  • Westchester Co., NY, USA
« Reply #2 on: December 29, 2017, 08:10:50 PM »
How far apart is going to depend on a few factors, and the best mixture/compromise:
- In a near-perfect world, at least one wavelength apart to get the antennas out of each other's radiating near fields (at 500MHz, that's two feet). In a perfect world, about 4-6 wavelengths to get the antennas solidly into their opposing far fields.
- Place the antennas so that each has an optimal, but different view of the desired coverage area.
- It maybe that both antennas can not have a full view of the desired coverage area, so you'll need to place them such that together they have a full view, yet not so individually, with as much overlap as possible.
And walk test thoroughly, with set pieces/obstructions in place, and video walls with moving images or full white.
Henry Cohen
Scott Hofmann
« Reply #3 on: December 30, 2017, 02:10:47 AM »
Good info, thanks!
Scott Hofmann
Scott Hofmann
« Reply #4 on: December 30, 2017, 02:11:29 AM »
Great info, thanks for your response!
Scott Hofmann
Scott Helmke
« Reply #5 on: December 30, 2017, 10:03:36 AM »
Ideally as different a view as possible - polarization angle, height, distance out from wall, etc.
Page created in 0.029 seconds with 21 queries.
