Hi everyone,
I am hoping there is someone in here who has experience with the internals of moving heads.
The ContextMy mobile DJ set-up is two Chauvet Intimidator Spot 355z IRC moving heads, one ADJ Warlock, and four ADJ Dotz Pars. I have them all on a T-Bar, and I control them with ADJ's myDMX 3.0 software. I use two ADJ WiFly Battery EXR transceivers to control the fixtures wirelessly.
I've been using these fixtures for about two years now, 100+ gigs, without any issues.
The ProblemI had two gigs this weekend, and one of my Intimidator Spot movers started flashing when it should
not have been flashing. It was following all my programmed movements / colours / gobos just fine, but the LED was flicking on and off the whole time. The best I can describe it is as a pulse, or a super duper slow strobe.
At my gig on Friday, it seemed to help for a few minutes when I disconnected and reconnected power to the fixture, but then it would eventually revert to the pulsing again.
At my gig on Saturday, it pulsed the whole time, so I ended up turning it off.
The TroubleshootingI set up my two movers at home today, and put them both into stand-alone mode, not connected to each other or anything else. I just let them run for half an hour and they both worked fine the whole time.
Next, I connected the "good" fixture (by itself) with a short DMX cable, directly to the myDMX dongle, and ran some shows for awhile. Everything was fine.
Then, I connected the "bad" fixture (by itself) with a short DMX cable, directly to the myDMX dongle, and ran some shows for awhile. It did the terrible pulsing thing the entire time.
Lastly, I connected the "good" fixture again (by itself), but changed it's DMX address to the same address as the "bad" fixture, to trick myDMX into thinking it was the "bad" fixture. It still worked fine. So I'm assuming there's nothing wrong with the software, cable, or dongle.
Is some part of the DMX communication within my fixture itself toasted? Does anyone have insight on this?
Thanks so much for your time!
Christopher Poynter
Victoria, BC, Canada
www.chrispoynter.ca
