Author Topic: Neutrik NAC3MP-HC 32A pre-punched panels?  (Read 1674 times)
Mike Christy
  • Southern Maine
    • Pisces Sound
« on: December 02, 2017, 08:24:51 am »
I can't seem to find 19" panels for the 32A powercons. Does someone have a source? Looking at the drawing it doesn't look like they will fit the G series cutout. They require 1.2" holes, the G and Ds are around 0.95"....
(I really don't need yet another Greenlee punch!)
TIA,
Mike
Pisces Sound
Southern Maine
duane massey
Re: Neutrik NAC3MP-HC 32A pre-punched panels?
« Reply #1 on: December 03, 2017, 03:19:44 am »
I have a set of Unibits that I use when I am just doing 1-2 holes in a panel.
Duane Massey
Houston, Texas
Bob Leonard
  • Boston, MA USA
« Reply #2 on: December 03, 2017, 08:06:27 am »
I couldn't find anything Mike, and 1.250" is not a small hole.
By the way, when did they get electricity in Maine???
Maybe here;
http://www.penn-elcom.com/default.asp?MC=04070501&LG=EN&title=punched-rack-panels
« Last Edit: December 03, 2017, 08:09:59 am by Bob Leonard »
BOSTON STRONG........
Proud Vietnam Veteran
Mark Wilkinson
« Reply #3 on: December 03, 2017, 09:42:23 am »
The 8 pole speakon connector, STX series is 1.22" dia.
I got some plates from Penn Elcon punched for them.
Maybe that could work as far as hole size......but I'm guessing the mounting screws might be an issue....
duane massey
Duane Massey
Houston, Texas
Mike Christy
  • Southern Maine
    • Pisces Sound
« Reply #5 on: December 03, 2017, 05:03:17 pm »
https://www.harborfreight.com/catalogsearch/result/index/?dir=asc&order=EAScore%2Cf%2CEAFeatured+Weight%2Cf%2CSale+Rank%2Cf&q=step+bit
Ya, Ive got one of those step bits, wonder if it'll work on 16 gauge...??... Maybe I'll try it...
There's some used 1 3/16" greenlees on evilbay, $15, that's not too bad I guess...
Ive got a drill press that I can do the screw holes, maybe thats what I should do.
Thanks guys!
Pisces Sound
Southern Maine
Mike Christy
  • Southern Maine
    • Pisces Sound
« Reply #6 on: December 03, 2017, 05:17:43 pm »
Maybe here;
Very funny, we have water wheels, and D batteries...
Pisces Sound
Southern Maine
duane massey
« Reply #7 on: December 04, 2017, 12:39:32 am »
Step-bit will work fine. Cheap ones may not last as long as the expensive ones, but they will all go thru 16ga, especially if you use a little oil.
Duane Massey
Houston, Texas
Mike Christy
  • Southern Maine
    • Pisces Sound
« Reply #8 on: December 04, 2017, 05:27:34 am »
Thanks, Ill try that on a spare panel. Will report back... - Mike
Pisces Sound
Southern Maine
John Fruits
« Reply #9 on: December 04, 2017, 05:33:01 am »
Have you considered finding someone locally with a CNC plasma cutter.  That might work.
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs.  There's also a negative side."-Hunter S. Thompson
Page created in 0.029 seconds with 20 queries.
