Pages: 1 2 [3] 4   Go Down
Author Topic: Just ordered a Qu-16  (Read 4337 times)
Tom Roche
  • Behind the Zion Curtain
Re: Just ordered a Qu-16
« Reply #20 on: November 08, 2017, 06:10:34 pm »
Dustin Campbell
« Reply #21 on: November 08, 2017, 07:15:17 pm »
QSC Touchmix-16
I like qsc a lot - was considering that one too I just wanted faders- how are you liking the touchmix ?
Banning CA,
Kemper Watson
« Reply #22 on: November 08, 2017, 07:41:49 pm »
on a side note I use a drive rack venue 360 - Im not sure how this will work with the Qu
It will work with the DR360 just like the analog console you were last using..
Mike Caldwell
  • Covington, Ohio
« Reply #23 on: November 08, 2017, 11:04:15 pm »
Since you have a DBX 360 take advantage of the AES input operating mode and use the AES out on the QU-16. That will save two digital conversion stages, digital to analog on the board output and analog to digital at the 360 input.
I use that set up with my QU-Pac.
You'll most likely find you like using the iPad more than the actual surface.
For an inexpensive good router I use a TP link Archer C7, only use 5g for your connection 2.4g is way too crowded.
Tom Roche
« Reply #24 on: November 09, 2017, 04:31:57 pm »
I like qsc a lot - was considering that one too I just wanted faders- how are you liking the touchmix?
I like it as it meets my needs for small bar band jobs.  It runs rather hot, so I may look into a laptop cooling pad or similar product to keep it running cooler.
Dustin Campbell
« Reply #25 on: November 14, 2017, 04:57:16 pm »
Iím canít seem to format my flash drive on the QU - I need to update the firmware - any suggestions please?
Banning CA,
Kemper Watson
« Reply #26 on: November 14, 2017, 05:49:26 pm »
Did you get one from the list of compatible drives? I came across a few that weren't usable
Dustin Campbell
« Reply #27 on: November 14, 2017, 05:59:13 pm »
Iíll double check
Banning CA,
Dustin Campbell
« Reply #28 on: November 14, 2017, 06:34:45 pm »
I have one that I formatted ok - now Iím trying to get the update on to the flash drive - it wonít open the zip file - it shows it as an executable
« Last Edit: November 14, 2017, 06:37:40 pm by Dustin Campbell »
Banning CA,
Stephen Swaffer
« Reply #29 on: November 14, 2017, 10:05:34 pm »
The QUs are a bit finicky about drives.  One word of caution I got burned by.  After doing a soundcheck for a show using the USB audio connection to the QU, I formatted a drive to record the show.  Somehow, formatting that drive broke the USB communications to the iMac(at least that's the only explanation I can come up with).  Rebooting the iMac fixed it.  Simple solution is to always format drives well ahead of time.
Steve Swaffer
Pages: 1 2 [3] 4   Go Up
Page created in 0.028 seconds with 19 queries.
