Pages: 1 2 [3] 4 5 ... 7   Go Down
Author Topic: Mount 12" box truss to confer block wall  (Read 2739 times)
Nathan Riddle
  • Panhandle, FL
Re: Mount 12" box truss to confer block wall
« Reply #20 on: October 16, 2017, 10:31:12 pm »
I appreciate your forwardness for life safety issues. But I feel that is taking things a bit too far.
Support beams into the foundation? The stage is 3ft high.
Saying the concrete wall won't hold the load up?
So now that I've chased them away they're using unistrut to mount to the concrete wall at the suggestion of AllProSound...
Definitely achieved gaining an engineering stamp of approval there. Along with someone who is 100% unqualified to do the work than someone who is only 30% unqualified.
Sorry for being passive aggressive, just kinda disappointed at the outcome.
If you HAD to choose would you rather me (someone who is going to actually calculate the loading and research the materials) or someone who would use TV wall mounts?
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #21 on: October 17, 2017, 12:19:41 am »
There is a difference between a concrete wall and a concrete block wall. For the blocks, the mortar is the weak point. I would not lag to it.
I know it was perhaps rhetorical but you cannot guarantee anything about the block wall.
You are seriously not listening to folks older and wiser.
Unistrut is a fine way to mount things. After all, it has engineering specs.
Nathan Riddle
  • Panhandle, FL
« Reply #22 on: October 17, 2017, 07:06:58 am »
To be clear, I am not doing anything.
Sure, unistrut is okay. But its being mounted to the same block wall y'all are so scarred of.
How is the mortar the weak point when the wedge bolt manufactures say that is where to drill?
« Last Edit: October 17, 2017, 07:13:56 am by Nathan Riddle »
David Allred
« Reply #23 on: October 17, 2017, 08:36:22 am »
Welcome to the land of "You can't win!".
« Reply #24 on: October 17, 2017, 12:44:03 pm »
What's wrong with Unistrut?  Assuming it's not held up by the aforementioned Tapcon's it's a tried and true methig.
Every Walmart you ever have been in has the network racks suspended from the ceiling by Unistrut and Spring Nuts.  So are the Air Handlers.
I would like to see drop (wedge style) anchors on the concrete wall.
River Delta Audio is now:
Nathan Riddle
  • Panhandle, FL
« Reply #25 on: October 17, 2017, 01:10:21 pm »
Haha, so true. Thanks for lightening the mood :)
I will report back with how they did it when I find out. Until then it will be ASSumptions.
Currently, I think tapcons will be used to hold the unistrut to the wall. Either that or wedge style lags.
"I would like to see drop (wedge style) anchors on the concrete wall."  (meaning you approve of this method?)
Jonathan Johnson
« Reply #26 on: October 17, 2017, 02:43:52 pm »
Tapcons are appropriate for lightweight loads such as conduit that won't be turned into monkey bars.
For medium weight loads, I wouldn't consider anything less than wedge style lags.
For anything that could be subjected to extreme shear or pulling force, a safer solution is through bolts that bear on the opposite side of the wall. Then you're not depending on the tensile or shear strength of the concrete at all; it's all compressive. And concrete has excellent compressive strength.
David Allred
« Reply #27 on: October 17, 2017, 04:00:09 pm »
I don't know if I would trust tampons.  Even though they expand to fill a void, they are removed too easily unless the string is removed.
Nathan Riddle
  • Panhandle, FL
« Reply #28 on: October 17, 2017, 04:19:21 pm »
Good point about through bolts, I was considering that if I ended up doing some work on it. With as much disgust with the wedge style lags into the wall I probably would have gone that route.
 ;D
I'll report back when I find out what they did, so we can all have a good laugh.
Stephen Swaffer
« Reply #29 on: October 17, 2017, 09:15:35 pm »
A couple of years ago I was asked to install some gooseneck light fixtures on the exterior of a century old plu building on our town square.  I've run into 2 kinds of brick in this town-some so soft it crumbles and some so hard you can barely drill a whole in them and they will literally take the threads off of tapcons.  My research determined the gold standard was expoxy based anchors in these situations.  I ended up settling on wedge based anchors in the mortar per the manufacturers recomendations (that made the historical people happy too!).
These were a much lighter load-my main concern was wind load.  The lights have survived a couple of Iowa springs with the attendant storms.
I would agree with Jonathan on bolting through if at all possible.  Use a large backer plate covering multiple blocks if possible.
I get the concern and suggestions for getting an engineer involved. My experience with engineers (in my area) is that it can be very difficult to get them to sign off on a small project-especially with anything like a stamp that transfers responsibility to them.  Perhaps in larger metro areas there are enough firms that it is a simple matter.
Steve Swaffer
Pages: 1 2 [3] 4 5 ... 7   Go Up
Page created in 0.029 seconds with 15 queries.
