Author Topic: Led replacement for halogen bulb  (Read 900 times)
Dave Guilford
« on: September 11, 2017, 10:03:56 am »
Let's say I have old American DJ Poclet Scan fixtures which use a ZB-JCR 12V/100W bulb.
 I've google searched but can't find anything one way or the other.  I want more brightness out of them.  Can someone recommend a LED replacement bulb I can't fit into it?  The bulb seems to be fairly common, but I'm grossly unknowledgable regarding lights.
Josh Rawls
Re: Led replacement for halogen bulb
« Reply #1 on: September 11, 2017, 10:41:20 am »
I would just start trying different LED replacement bulbs. You can find them all over the internet. One place to try is www.superbrightleds.com. The problem will be finding one with the same focal point. That could make a big difference in performance.
Josh Rawls
kathelin motaz
« Reply #2 on: October 02, 2017, 08:19:26 am »
Hi Dave,
a 100-watt halogen normally gives 1000 lumen, there are many solutions for you, if you want to replace it with another LED bulb then you will find a max 1250 lumen. if you want more you still should look for a lighting engine that can fit in the same place of the current lamp and in that case you can easily go up to 2000 lumen.
you can use the dedicated search engines for lighting components such as
archiexpo.com
lightingarena.com
if you still need more help with recommendations let me know
all the best.
Kath.
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #3 on: October 02, 2017, 09:08:13 am »
Hi Dave,
Kath.
Page created in 0.031 seconds with 18 queries.
